  • Replies 403
rchoo, CrispyFries and Sarumatix I recon your 4 doors look great.
-Ben
Thanks Ben :banana: Your's looks pretty nice as well!
We should try to get more 4 doors out to DECA, we had 2 last time.
your 4 door looks pretty good merlin, and thats some pretty fat rubber on the back!
What is the front spoiler that you have on yours? im looking at getting a new one soon and that one looks alright.
-Ben
Cheers for that inark, i ended up doing a bit of a search on the net theres some alright ones other there i just didnt want anything too full on. i was thinking of getting a full kit but still unsure if i want to go that way yet.
the one i had on my one was pretty dam nice... Final Konnexion. Rear bar was pretty huge... looked hot tho.
I believe Jetspeed stock the kits
http://www.finalkonnexion.co.jp/english/li...eup_nissan.html
Hmm, I'll have to decide what kit I'm going with eventually...
Anyone know where to get 33 4 door skirts cheaper than carmate?
PM me the kit details and price carmate has quoted you. I should be able to get it cheaper, we buy a lot of stuff from them.
Cheers Hus, I'm months away from getting them though. Carmate is just the cheapest 4 door gtr style skirts I've found so far on the web. Will shoot you a pm when I'm actually ready to do something about it.
J
screw 4 door GTR skirts... get those FK ones... i reckon the R33 4 Door kit looks good unlike most R33 kits. If your gonna pay top dollar (which u are going to) you may as well get something less stockish.
on 2nd thoughts those skirts would look silly unless you had a full kit cause theyre huge... SO GET IT ALL!!
:P
haha, do you have fk shares or something?
it's too out there for my liking, prefer something a little more subtle and less VIP looking :P
The msports is a bit better, but I don't like the bottom of the front bar. Hard to tell what any of those kits would really look like anyway with those dodgy photoshopped wheels
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
