  • Replies 403
yeah same kit but not lower... i meant urs was lower and with better wheels :)
hopefully i get it before it sells... its gold... then all we would need is a bronze coloured one for the full medal count :)
well got a pic from todays 4 door cruise, and a new dyno sheet as of friday so post it up to
mods are
Internally standard Rb20det
Garrett dual ball bearing 450hp turbo (same as a gcg hiflow, this is using a 33 comp cover)
RB26 PFC modded to fit RB20
Walbro 500hp fuel pump
Splitfire coilpacks
FMIC - cheapo
catback tanabe exhaust, punched out cat, standard front pipe/dump pipe
standard afm, injectors
running 11psi on turbosmart t-boost due to nearly maxing out injectors
soon to have front pipe and dump pipe, z32, 550cc inj and 18psi
Yeh was ment to write that to but forgot, was gona get one cause i know how restrictive the dump/front pipes are
The front dump pipe and high flow cat can add 20-30kw, not sure about the hollow cat though whether it is more efficent than a high flow? ($$$ if you get caught).
BATMBL often has group buys on here and Just Jap have one too. Worth getting with the work you have had done.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
