The front dump pipe and high flow cat can add 20-30kw, not sure about the hollow cat though whether it is more efficent than a high flow? ($$$ if you get caught).
BATMBL often has group buys on here and Just Jap have one too. Worth getting with the work you have had done.
Yeah i need to tdo this...
  • Replies 403
I would almost buy that if it wasnt for those rear lights... and the front... and it being a 33... but apart from that i seriously would
You forgot to mention the 2 extra doors..But i also hate the rearlights..
That sucks, would you consider fitting a series 2 panel?
Yeah
If the price was right..
Also..
Would i be able to use the tail light surrounds with series 1 tail lights
coz i dont like the way series 2 tail lights stick out that inch..
Cheers Wayne..
If you have these give me a buzz on 0437987467.. :)
I just had this guy back in to me so im after this Boot panel
If you have 1 or know were i may get 1 let me know..
Cheers guys....
PM me or
Ph ..0437987467
It took a bit of hunting but i found 1 250$$$$
This prick better pay up..
The phone number he gave me is already dodgy..
I may need to pay him a visit..Hey.. :)
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
