  • Replies 403
That looks so good Nathan, remind me not to park near you in the future, makes mine look boring. :P That front spoiler is low though, does it scrape much?
Cheers
Just washed her for the first time since bonnet conversion, painted the red S silver and took some pics.
Thanks Issy, isn't really that low, previous cars have been much lower, is actually quite user friendly with no scrapes so far, although i am thinking of getting it lowered a bit more.
I now have the sydneykid suspension set up (minus the stabiliser bars) and my standard front bar scrapes a little coming out some driveways, grrrrr, just gotta be careful. :thumbsup:
Here is a few pics of my sedan from winton for the first time and a couple from when i was installing an oil cooler.
This was Crispy Fries sedan before i got it. Its undergone a few changes mainly relating to performance and realibility for the track. The main parts on it atm-
Greedy FMIC
HKS filter relocation kit/oil cooler with earl and speedflow fittings
Kaaz 2 way diff
Work VS 17's (8's on front 9's on rear) I run 235's on front and rear for track use
Defi Din guages (oil temp, oil press, water temp)
Whiteline swaybars
Whiteline castor bushes (running 7 degrees)
Bilstein shocks/whiteline spring combo
Whiteline front strut brace
K'N pod filter in Hi Octane heat sheild box with custom cai
4 point Harness
Batmbl spilt dump/front
Hi flow cat
Trust twin tip exhuast
Hicas lock bar
Custom sump bashplate
Thats all that i can remember off the top of my head. Slowly will start to change the suspension now that i have had a proper track day under me. Im hoping to still retain its nice streetability and not go too track orientated. Then from there i hope to improve in the looks department BUT never having a cop look at you is very nice while im still on my P's!!!
I now have the sydneykid suspension set up (minus the stabiliser bars) and my standard front bar scrapes a little coming out some driveways, grrrrr, just gotta be careful. :D
That looks much better, how much different is it on the road? You'd better not park next to me in the car park cos when you leave it'll be without those mudflaps.
Spoke to soon about my bar height, got my first scrape today. NOT HAPPY.
Bummer, doesn't it make you angry, especially when your bumper was perfect to start with.
You can feel the road more, but it does hug the corners and feels so secure, oh yes and it looks better.
I will swap you my mudflaps for your side skirts!!!!
Seriously want your boot spoiler, can't find one anywhere, $1100 brand new from Nissan including brake light. Ouch!!
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
