Seen a few 4 doors in my area of late..
Where are you all from ?
I live in Berwick............Skyline Country
Also with the weather starting to pick up i might see how much interest there is in a 4 door cruise
  • Replies 403
Here is my 4 Door, though not sure if I am "allowed" in this thread all beit me being from NSW.....
See more pics in my Album - link in signature.
Currently the only mod is the body kit, only had the car for 6 weeks... plans to do a whole lot more.
Drew.
lol guys, I get upset when I my husband gets attention driving my R34 GTT sedan, I feel like yelling out the window "Noooo its my car not his!!!" :woot: although I still love driving his R33 GTST cause it is a manual and sounds better. Then I'd claim that as our car. :D
Had it for about 4 months, swapped my CA S13 180SX For it. No real dramas other than gearbox 4th syncro, getting rebuilt very soon. and the hicas which stuffs up at random. generally though not many dramas, 92 model with 158 thou on the clock.
Whats mine is mine, whats hers is mine :O
Awesome! :sick:
Its nice mate. :O
Does your Hicas light come on when you drive in a straight line for 10 minutes?
If so and you have a aftermarket steering wheel, your hicas sensor in the steering column is not centralised with in the locating point of the boss.
Drew.
Everyone is welcome here,
I like 34's but i would have to have the Uras Monkey Magic kit if i did it or a V35 coupe with The Impul Kit.
Hey 33 4 door ppl, has anyone removed the rear garnish? I'm gonna give it a whirl this weekend. i wanna paint it same as body colour. i tiried quickly last weekend, removed the visible screws but still didn't come off.
Post a pic after you have done it i would like to see how it came up
Dude, that would be awesome, just after i wash my car on a warm day i get an awfull condensation look on the plastic and it would be great if someone knew how to remove the cover (without damaging anything). Good luck with it.....let us all know how you went.
PS) if your in Adeliade please check out my link to "CRUISE FOR A CAUSE" at the bottom of my posting.
Thanks Guys...
Kind Regards Evan
I think that panel is double side taped on, My car has an add on cover, available from Garage Impul motor racing Developments in Japan.
I checked out pricing some time ago, but can only remember the cost of the entire kit........ $ around 7grand........
[/quote
Open the boot there is 4 bolts holding it on remove the nuts . Then remove the arm off the lock.
Then get your fingers under the panel . Now it has a glamp you cant see it just start pulling it up
when it comes off you with think you have broken it its just the clamp.. goog luck..
  • 4 weeks later...
ow did you go.. did you paint it..
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
