hey guys a mates r33 gtst out of the blew has started to idel very rough and it begain to over heat so all hoses have been changed and flushed the system and added coolant.... also when car is turn off water in the overflow bottle is bubbling???? anyone know whats going on
all help is much appreciated???
take the radiator cap off and let the engine idle, if the water bubbles and froths up and has oil in it then u prolly blew a head gasket, take it too a mechanic they got a thingy they put on there and if it loses compression etc etc.
I guess this wont help, but anyway...
Had the same prob on my BMW, the earlier owner had changed headgasket, rebuild the head, and changed cooler along with some other things, when i bought it.
It acted the way you describe, but there werent any oil in the water etc, and if it idled for a somewhat long while it started to stutter, and the water in the overflow bottle started bubble.
Someone mentioned i should check if there were air in the watersystem, and there were some, got it out and now its a whole lot better.
Probably wont help you but who knows, it might :thumbsup:
bleed the radiator again, using the tap near the plenum that has the label "do not open when hot"
other test is for exhaust gas in the cooling system.. they put it over the cap and it changes colour if gases are in it...
for $330 for a cometic metal gasket and time if your mechanically minded then you can fix it up easy and cheap if it does show gas.
water is going out the exhaust brother, Chemical testing the system is the way to go, blown head gaskets dont always blow to an oil gallery, most common is cylinder to cooling system. other test is to pressure test cooling system with spark plugs out, then crank engine, if water is blown out of spark plug tube, thats bad.
something has caused the car to overheat, repair leak, check thermostat, flush radiator. Blown headgasket is the result of something else failing.
' date='23 May 2006, 06:34 PM' post='2194735']
could it be the water pump?
where does the leak go to?
Edited by Bezerkly
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
    • Awesome thanks for the reply Man! I already plugged up the back just cause I can’t take a chance on it leaking on me again haha. But i will fab a catch can with 2x for the cam covers and a lower one for the sump vent.    Now as this will drain back as well , Is there any concern I should have of the oil being drained back. I don’t run e85 or anything .   2nd question is, from the picture does it seem that my sump fitting is above oil level? Silly question but I rather have someone’s experienced opinion lol
