I've just got a Garret T04Z (0.84) for my RB25. I was just wanting to know if anyone has seen one if these things perform on a 25 and how they go? when would i see boost etc. I have supporting mods for it like Power FC / Fuel / Injectors and all the rest but i don't have cams at the moment and was thinking maybe they would be something good to put on at the same time to get some better figures and power curves from it? Any info appreciated. Thx
https://www.sau.com.au/forums/topic/118339-t04z-on-rb25det/
Tomei Pon Cams are your friend :thumbsup: PON CAMS
https://www.sau.com.au/forums/topic/118339-t04z-on-rb25det/#findComment-2177373
