hahah serious, i have never come across a thread like this..
However i did notice last week there was a thread on gtr cop car.. but didnt bother to open it..
ohh well..
EDIT: ok have seen most of these pics last year.. just forgotten about them.. my bad
Edited by siddr20
https://www.sau.com.au/forums/topic/118343-jap-cops/#findComment-2177776
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
    • Isn't this what everyone immediately sees in their mind's eye when someone gives them a total width number and an offset?
    • It won't be this - not while it's driving, anyway.
