it stays flat. has its little jerk and then goes again but up high rpm around 6-7 you cant feel much.
i have front mount, 3 inch all the way, filter and BOV
i have a full exhaust with a shit tip from japan which came with the car.... its like an oval shape one.. pretty quiet not like a cannon..
like a stock GTR exhaust with a 4inch tip....
Sounds like the rich and retard thing.
Check out this old dyno sheet of mine. The lower line is no boost controller turned on, full exhaust, stock cooler. The upper line is 12psi of boost. See the dip in the power? It was very noticeable on the street.
I dont get it.... Adam... you got only 100 RWKW on stock boost?! how is that possible?!?! and only ~150rwkw on 18-19 PSI?
I used to run around 12PSI on that pheunamatical mehcnaical boost controller from SidMark on a stock exhaust and EManage. Was I restricting the power?
yeah thats it...
same as you abo bob....
thats how i feel but you can feel it bigtime on the streets....
heard it was rich too... but man i cant see from the rear mirror....
so if i was to boost my car to 12psi cooler full exhaust filter...
how much you think i can push?
or how much does everyone else push?
Edited by ZERO
  Abo Bob said:
A few people have hit R&R without a boost controller but I installed one in the above example.
darko - ???!!!?!?!! wtf? Have a closer look.
oh oops haha
my bad
was that while u were running everything stock?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
