'please move to General Maintenance, thanks'.
Recently I had my 100k service done & the thermostat was replaced. I was wondering would this affect my climate control.
As you should all know, the minimum degrees selectable is 18, max 32.
The problem is the second I raise it over 18c, it feels like the max 32c. So when on 19c 'or above', it feels like 32c?
Any ideas?
Thanks, :wave:
EDIT: Actually, my odometer was replaced not too long after the 100k service 'due to it stopping :|' & I think this is when I noticed the climate control playing up. I spose they had to remove the dash to get into the odometer. Any possibility a hose / connector / sensor for the climate control came disconnected at that same time?
Edited by geno8r
https://www.sau.com.au/forums/topic/118440-climate-control-playing-up/
I think this i s a pretty common problem in the r33's. It seems that if its not hot over 18c, then it just isnt cold. You would think that 19c would be no different to 18c. I dont know the solution, whether its a mechanical problem, or more likely, a electrical problem. But try searching because there has been quite a few threads on this issue.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
