THe R32's I've seen appear to all run the crappy H3C bulb.
Crappy because they are expensive and are not available from most places.
The H3 can be fitted but you are required to earth the headlights globe suround in order for them to work.
While your there you may as well slap them on a relay to prevent the common switch burnout problem the R32's have.
The R32's run the full current through the switch, not a relay as it should be done, the result, melted plastic around the contacts.
The only real benefit with the H3 globes is there are 30% and I believe 50% brighter globes are available from Navara (spelling?).
I went to autobarn for the H3C, they wanted $17 each for some generic looking globe.
Unsure what the early model ones run as they don't run projector head lights.
don't they? hmm.. might have to remove mine then :D
I was just looking at it the other week .. the "projector" is h3c.. and the other highbeam is a JA12V.. which I've been told is a standard H3
Non projectors 32 used H4 ( lucky bastards :nyaanyaa: ), i have a projector and i have to imported a H3C from RAY BRIG in Japan as the AutoBarn ones just not bright enough.
Projector lights are normally on late model r32 regardless gtr or not and they used that stupid H3C BUT late model N1 use H4.
I have had projector headlights with both H3C and H1 globes in mine. Not sure when they changed. Only physical difference between was the projector bulb itself. The H3C bulb was more smokey in colour to the H1 which was whiter (i think, i cant remember which way around it was now)
Mine has h1's in the low beam projector. sept 92 model, no idea about the others, haven't had to replace them yet.
Avoid narva like the plague, i bought a twin pack of the arctic white and they both died within 2 weeks of each other 6 months later.
  • 5 weeks later...
In QLD at least, a blue tinge is not considered to be a "blue" light and is not defectable.
In my R32 Type M '93 I just replaced the headlights with H1's (55W of course) and I replaced the park light that had died with a W5W - which is a 12V - 5 Watt standard bulb.
Funnily enough, the W5W parker bulb cost $6 on its own, when all the other parker bulbs (12V with slightly less watts) were 2 for $5 of $6, what a rip!
Some idiot before me put in a H1 - 100W Rally light in my headlight, instead of a normal 55W, it kept melting the fuse at the fuse box, and also melted the plastic around the globe itself. Let it be known to everyone, just because it's higher in watts, doesn't mean it's brighter. The new H1 55W I put in, is a lot brighter, and I now have good headlights, whereas before I could hardly tell I had my headlights on sometimes.
Fixxxer :D
i have a 91 R32 GTR, it had the projector type with the H3C bulb in it, they are soo cr a p at night i just couldn't hadle it.
my mate has a 93 R32 GTR & he has different looking head lights, they take a H4
easy fix, i put 93 R32 Headlights in mine & now run PIAA H4 Bulbs & can now see at night!
:D
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
