For the past two days I have spent my afternoon and evenings at the new dyno facility in Campbellfield called Drag Tag. When I first heard of the concept I thought it was a great story, hell was freezing over and cops where flying south for the winter.
Its hard to describe things that simply have never existed before, so the only way I can describe it is the best car game you have ever played but you use your own car.
Here’s how it works. Currently they have three operating cells. Each cell consists of a 4wd dyno to measure you cars power and breaking inputs, a state of the art laser system measuring the front wheels angle for steering inputs, a pneumatic clamp down system to hold the car on the dyno and a 260 degree screen in front of the dyno. The dyno and lasers are hooked up to 5 computers. These computers measure your cars inputs and relay them into a driving simulator that is projected on to the 260 degree screen with graphics and scenery comparable to any game on the market. You drive your car on to the dyno, put it in first gear let out the clutch and you start moving along a virtual road. Turn right and you move into the right lane, turn left and your back in the left lane. Keep turning left and you on the foot path. Give it some stick and you find your self quickly approaching a set of traffic lights that are red. When they turn green you can go. This is your opportunity to do what you’ve always wanted to do early on a Sunday when no one is one the road. Floor it. So you dump the clutch and wheel spin of the line screeching all the way. Grab second with a little chirp and then she hooks up and your off, you grab 3 and you are hurdling down a deserted road out the back of an industrial lot and stuff is starting to move real fast. Grab forth gear and the car is starting to wonder over the road a little but that’s all good you just steer out of it. FLASH shit you’ve been done by a speed camera. Well that’s what I thought anyway. That actually means you’ve just run a quarter mile. All of a sudden the scenery disappears and all your cars stats come up on the screen, power, torque, reaction time, 60 foot, ET and how you positioned against the guy in the cell next to you in his WRX. All the scores get recorded and compared against everyone ells on the day and every one ells that’s competed in the past.
This is virtual racing in your own car, using its power and your driving ability. Its not just limited to drag racing either. You can race around circuits, rally driving and the soon to be developed drifting. The days of you and your mates jumping in a row of Daytona games are over. Now you can still race against each other but now its in your own cars, three wide, with no risk.
Currently they are having free open nights on Wednesday and Thursdays. The last one I believe is next Wednesday and Thursday. This is your last chance to see what its all about for free.
As I said I was there tonight and I couldn’t help picturing SAU vs WRX club drag tag.
I highly recommend you check it out and that the club looks in to having a Dag Tag event.
www.dragtag.com.au
Cheers,
Adam
p.s. All your stats get posted on the net too.
Here are mine
Car Stats - DRIF6
Drive Stats
Edited by Adz
https://www.sau.com.au/forums/topic/118467-drag-tag/
60ft of 1.34 secs... you running slicks on that thing Adam? :D
I heard rumours you were out there checking it all out heheh
Na no slicks. Just did a big dirty clutch dump in 2nd from a stand still to get some heat in to the tyres and dyno.
Yeha been there the last couple of nights.
Edited by Adz
https://www.sau.com.au/forums/topic/118467-drag-tag/#findComment-2180688
it may be accurate, just tell you what your car is 'capable' of but a little unrealistic...
i noticed the guy i bought my car off said he had something to do with dragtag, he has the VCMSuite Monaro on the register running flat 11's... it is a Supercharged LS2 but have a look at his 60 times!!! 1.2 sec?? i doubt it
https://www.sau.com.au/forums/topic/118467-drag-tag/#findComment-2181142
The 60' component is the only thing that needs work. It effects the incrementals but the end results (1/4 ET and TS are very accurate.)
There is already a thread discussing this with Russel from Drag Tag a member of SAU.
Adrian
https://www.sau.com.au/forums/topic/118467-drag-tag/#findComment-2181215
ill be sold when i see a car that has consistent times down real drag strips getting the same figures on dragtag...
If the 60 foot time is out, how can the 1/4 be accurate??
Goin by my calculation, (correct me if im wrong) That monaro ran a flat 11 with 117mph... Does not seem right at all.. it should have massive top end with a blown 6 litre.
https://www.sau.com.au/forums/topic/118467-drag-tag/#findComment-2181220
something i'd be worried about would be things while drifting or curcuit racing would be feeling the weight of the car lean, and the g forces involved, it cld end up being a one handed affair, and then the people end up racing at a real track and come into grief ...
there is no substitute for reality
but hey, this mite make calder n heathcote charge less
https://www.sau.com.au/forums/topic/118467-drag-tag/#findComment-2185481
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
