Wtb Urgent R33 Hycas Lock Bars ( Got One, Thanks To All Responders)
As topic title says we need ASAP a set of hycas Lock Bars to suit R33 Skyline.
The car is entered in the Queensland 500 on 28th this month...so we are fast running out of time.
Edit Thank you all responders. GTRGeoff is supplying one.
Edited by 51jay
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
