Hi all,
I've been having this problem for about 6 months now, but I've been too lazy to fix it.
Basically I've got incredibly heavy steering - almost like I've got no power steering - and when I turn the steering wheel slowly, the revs don't rise like they used to. The fluid levels are fine, so it's not that. I had Mark at Hills hook it up to his little diagnostic machine and he said some sensor for the steering was screwed and not sensing properly (possbily on the steering rack? I can't remember). Does anyone know what this sensor is? This all seemed to happen when my wiring burnt out and I had to get it replaced (the guy in Japan did the DODGIEST wiring on his gauges).
I've also got error codes 22 and 32 for my HICAS which is kind of bad too I'm sure. I'd also like to get rid of that. Anyone know? I read a thread a while back that said if some wire from the speedo to somewhere else was missing, then the HICAS would give error codes. Does anyone know about this either?
Sorry for all the questions :D
Cheers,
Michael
https://www.sau.com.au/forums/topic/11851-heavy-steering-hicas-faults/
Yeah I'm pretty sure it's a wiring problem, as I had the whole thing rewired when it burnt out. The thing is though, when the steering wheel is turned hard, power steering kicks in. This would mean the right wire is attached. It makes it a bitch to drive in relatively smooth curves in the road as I can't always tell when the power steering will kick in.
Randy, I haven't checked it out as I thought someone here might have been able to just say "it's the XX sensor on your steering rack". I might have to take it in to a place like Whiteline if I can't resolve it myself.
Has anyone looked at their steering rack? Are there any sensors on it at all?
Cheers,
Michael
  • 1 month later...
Guest liamjones25
i had a similar problem while driving my r33 gts-t...
we were going around a corner at slow speed, and for some reason, the steering went incredibly heavy, like the power steering had cut-out and the HICAS warning like came on...
As to why this came on, i don't know... any help would be greatly appreciated!
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
