Hi Guys,
Over the past few month i have been saving my pennies for a R34 GTT which the nice one seem to be sitting at around the 30k mark
now heres the catch a mutual friend is selling his 94 GTST for a great price he has offered it to me for $15,000
he purchased the car 2 years ago as a clean unmodified car he has done full exhauste from turbo back double dump, blitz front mount (cant be seen from front easily) apexi power fc and hand controller trust boost controller was all fitted and tuned together with 12 psi dialed in and has not been touched ever since.
Has been serviced every 5000 good oil and has never broken down or boosted over 12
looks wise it has a subtle after market front bar and 17" work rims 275 tyres on the back
i drove it and goes like a wet dream
1. do you think its a good deal considering i know all the history of the car
2. will the power fc and coilovers go into a 34GTT when i get one in say a years time
what is you opinion of the power fc?
Basicly i can get this car now and get rid of my clapped out lancer
or drive the dunga lancer till december when funds should permit and get the 34
cheers for the help
Dan
https://www.sau.com.au/forums/topic/118513-thinking-of-buying-a-33/
You will loose money if you buy the 33 then sell it a few months later to buy a 34.
That 33 sounds like a good deal if it is in as good condition as you believe.
Personally I just buy the 33.
My advice, if you really want a 34, wait and just buy that, don't buy the 33 with the intent to sell it. If you want a car that goes well and looks good, buy the 33 and save the rest of the money.
Good luck.
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
