I have a s1 r33 gtst.
Until a few weeks ago when i start my car when its cold, immediatle after the car is started it makes a high pitch scretch noise which last for about 1-2 seconds, then the oil pressure guage starts going up. SOunds comming somewhere in engine bay.Has this happened to any other skylines?
Car is not losing oil, or no coolant, and still drives normal, and cranks up normal, but dunno where the scretching noise is comming from. DOes not do it when the car is warm. Is it the starter motor?
https://www.sau.com.au/forums/topic/118516-wierd-noise-during-cold-startup/
Check your belts.
Could be slightly loose, or it could just be a small amount of moisture from condensation causing a slight slip.
All belts seem tight..could it be comming from inside the engine block? i hope not
also right after i turn the key to start the car and just before the screech noise will sound the revs sort of struggles to go uo, and right after the screeching noise is done the revs will go up to normal about 1.3rpm when cold.. would not have a clue what it is, but the noise is very annoying
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
