remote Breather tanks for radiators ..
already running a PWR 40mm radiator but she still bubbles a little after getting hot ..
are kits like this useful on systems that already run header tanks with the presuure caps?
only ever seen them on sealed cross flow units..
any ideas??
https://www.sau.com.au/forums/topic/118629-remote-breather-tanks-on-radiators/
Hey Chris,
I got one of these installed; main reason for it is to remove air locks which it is doing just fine.
My tank is setup where the stock charcoal cannister is and does the job pretty well!
NB: There is a T-Piece that you require in order to make the product you've shown work, it's not included!!!
S
oh, i thought u already had one. how come the plenum now stops you from bleeding the cooling system?(never done any cooling system work on 33's maself) i cant really see how they would be of much benefit on a system that already has a header tank with pressure cap though.. basically, they do the same job. does the factory header tank have any form of 'breather'? if not then this might do sumthin for you
Hey Chris,
S
hmm would like to see how its hooked up, cant really picture it... does it pull a water feed from somewhere like where the std water bleed is?
the front facing plenum relocates the TB, and since it dont really snow here i didn't run the water feed through the throttle body .. hence its removal..
Edited by Craved
The tank is situated in between the overflow tank and the radiator... in total I think there are 4 lines coming off the thing, 2 going back into the radiator (well one from and one back to)
The other hoses then go to the over flow and one has a one way air bleeding cap (trying to be descriptive)... it lets air out but not coolant (?!?)
Not 100% sure, the boys put it in and said it works :wave: I'm happy and was content with a 80% understanding :wub:
hahah once i see it i will get it fine..
can see where the return from the tank to the radiator would enter the cooling system as the pressure cap on the radiator wouldn't allow water back in very much.
got a picture Stan?
bleeding air from the system is extremely important - more so than people generally think. air in the cooling system is a killer and will turn the block into a kettle - particularly when we have lengthy 6 cyl engines and there is a significant temp differential between the front of the block and the rear as the water from the radiator only enters at the front.
some aftermarket chevy heads now have cooolant take offs half way down the side of the head for that reason - more even core temp means more consistent combustion and more efficiency.
the breather tank is probably a good idea in a high hp engine, one that operates at higher temps for long periods or one that has no bleeder :O make sure it's at the highest point of the cooling system otherwise it just acts as an extension of the water jacket and, instead of turning steam into condensation will recirc the steam.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
