Firewall Gromits in R33
I *guess* you could just make the hole bigger where theres power cable. I'm not 100% sure, good person to ask might be FRISKI as he's done heaps of installs on R33s and no doubt done quite a few power wires n stuff thru the firewall....
Hye dude, there is one above the pedals on teh right hand side of engine bay about half way up... its hard to find but i run everything though here for alarm, boost controller etc... go under ya pedals searh up there to the right hand side and peel the carpet back a little and there is a gromet bout 20c piece in size.
Guest INASNT
nissanpowers pic is on the $$. theres a grommet just under the abs unit where u can pass wires through. There will be wires going through there already.
when installing my stereo in the R32 i was bitching to my dad about having to drill a massive hole in the firewall to put the sub power cable through. looking i found two massive holes about the size of my fists (almost), one each side of the engine bay to place wires through to the cabin. it has some foam in there which you place back once you have put the wires through..
unsure if the R33 is the same, but take a look as there hidden away :(
Shaun
Guest INASNT
Originally posted by 400HP
Did you guys remove the ABS to do it or was it not in the way?
u dont have to remove anything.
y can clearly see the grommet with the wires going through just near the abs unit
  • 2 months later...
Im confused... I can see the existing grommets that go through but to get the hose for my boost guage through do I need to drill somewhere or is there a place I can just stick it through?
i am mounting the guage on the pillar...
Guest INASNT
just cut a small hole in the grommet and rip it abit to fit the boost hose through! Just make sure it doesent get stuck along the way on anything or u will get false boost readings
Guest INASNT
pass it through the passenger side grommet coz u will never find the hose going through the drivers side grommet
heh guess what.... I did. took a while and it seems a bit dodgy but I got it through there... kinda goes out the side and comes in where some wire from the door goes... works for me.
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
