well fellow stagea owners and prospective new buyers i came across this stagea in a sydney caryard http://www.uniquemotors.com.au/unique_moto...car.jsp?id=1549
Now most of you guys can make up your own minds but im posative its a car that was on jspec a while back that i was looking at to purchace but didnt because it had heaps of klms on it .here are the jspec details i have .2000 Nissan Stagea RS FOUR V turbo .. leather interior
2.5L NEO6 turbo 4WD
Tiptronic
pearl white
155,000 km's
No major accident history
One owner vehicle
Power steering
Power windows
Air conditioner
ABS brakes
Dual air-bags
Dual sunroof model
LEATHER INTERIOR (rare option)
Heated seats
Front power seats
18" BBS alloy wheels
Adjustable suspension
Additional details can be requested
... available now for 705,000 yen FOB .. around $16,500 landed and complied i have the pics for this car also and if its not the same one ill stand rooooootin.it seems to have lost a bit of weight in the klm department to me but ill let you guys decide.regards mike...........dont get stung........
https://www.sau.com.au/forums/topic/118642-beware/
  • Replies 41
2.5L NEO6 turbo 4WD
Tiptronic
pearl white
155,000 km's
One owner vehicle
Power steering
Power windows
Air conditioner
ABS brakes
Dual air-bags
Dual sunroof model
Heated seats
Front power seats
doesnt surprise me at all, dealers are always doing it to imported cars. do you have the jspec url or photos?
https://www.sau.com.au/forums/topic/118642-beware/#findComment-2184402
For anyone that is in NSW and feels like it is worth while Office of Fair Trading
It's not really the price that is the issue here, they can charge what they like, if someone wants to pay that then they can sell for that. It's the odo reading that is breaking the law...
Edited by munchdesign
https://www.sau.com.au/forums/topic/118642-beware/#findComment-2184559
You might find this is whats happend
- Jspec tried to sell the car, they couldnt but it was left up
- Broker in japan sold the car to the importers with false KM's
- Broker changed KM's when importer said, ok
- Jspec eventually got someone interested, asked if the car was still available, and it wasnt, so it was marked as "sold"
It happend to me when i wanted to buy another car, it was already sold by the supplier in japan by the time i asked....E&M might not even know about the KM's being wound back.....so take it easy.
Otherwise, so what, they can just say it came with that KM's from japan and they dont know anything about it. Nowhere on the import papers does it say the km's of the car......
https://www.sau.com.au/forums/topic/118642-beware/#findComment-2184812
Already been taken down.. interesting..
seems to me that someone is up to no good didnt take long for the company to remove the listing though
least it shows you that the cars that j-spec list have genuine k's on them even if dodgy dealers chage them
https://www.sau.com.au/forums/topic/118642-beware/#findComment-2185062
someone might have sent them an email... ;) Says something I guess, either along the lines of what Alex said or that they had some involvement.
https://www.sau.com.au/forums/topic/118642-beware/#findComment-2185082
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
