the silencer on the xforce barely does anything
i tested it on and off, and i couldnt feel a difference
takes the edge off the noise though. and it would depend on how much power you have as to how much power it takes off. someone pushing 350-400hp would notice a bigger loss than someone on a stock turbo at stock boost.
  • Replies 83
hrmm, so if epa tests an xforce muffler with the silencer and it passes, would this be the valid reading? or would they have to test the exhaust without the silencer?
I was going through some of the regulations in relation to testing procedures and here's what i found:
PROTECTION OF THE ENVIRONMENT OPERATIONS (NOISE CONTROL) REGULATION 2000 - SCHEDULE 2 - Testing Procedures
5 Vehicle operation and noise measurement
(b) If the Engine Speed at Maximum Power (ESMP) for that engine has not been determined by the EPA—the engine is to be brought to and stabilised at a speed as close as the authorised officer can achieve to one of the following speeds:
(i) if the engine has 5 cylinders or less—4000 rpm,
(ii) if the engine has 6 cylinders—3200 rpm,
(iii) if the engine has 8 cylinders—3300 rpm,
(iv) if the engine has more than 8 cylinders—4300 rpm,
(v) if the engine is a rotary engine—4500 rpm.
© If, in the opinion of the authorised officer, the test speed determined by reference to paragraphs (a) and (b) is not attainable by the engine—the engine is to be brought to and stabilised at the maximum speed that the authorised officer believes that the engine can be safely tested.
Hi guys,
It seems the Apexi bomber exhaust has a dB reading of 98. The N1 has a reading of 94! The fujitsubo legalis R has a reading of 94db (@5100 rpm), while the fujitsubo STD exhaust has 92dB (@5100 rpm).
My question now is, will this level reduce once the BATMBL dump/front pip and large cat is installed? The Apexi cat back (bomber or N1) was what i was looking at - but the sound levels seem to be in the illegal range. I know that the different type of mufflers matters to reduce the sound. Any types that you guys recommend?
Thanks in advance.
Hi guys,
Thanks in advance.
if you want legal, you should buy my cat back :P
tanabe 3" mild steel, oval muffler (JASMA approved :O)
see sig.
Trust PE2 specs from what I remember shows 90dB. But I'll assume this changes once you put an aftermarket dump/front pipe in with a high flow cat.
From my experience the PE2 is quite quiet compared to other brands of catbacks. Having said that it still shows the nice RB groal when you hammer it :P
ey guyz i just got home from work (im a mechanic)....and i finished fitting my X-force 3inch turbo back on my 32...the exhaust cost me 950 from just jap....i actually thought that it would be much louder...at idle its a little bit louder than the stock one...i jumped inside and gave it a rev....when you get higher in the rev range thats wen it starts to become loud...i havent driven it yet tho i will first thing tomorow....but the xforce i found is really quiet at idle
And as you said, old stuff...
The are old regulations.
RB25 is 4800rpm
RB26 is 5200rpm
RB20 (i think) is 4500 or 4400rpm
The above supplied is the old regulations that were changed some 18months ago for Vic and are now motor specific, not generalistic
cheers
I heard the testing in brissy is that they check the dB rating at 2/3 of yer maximum rpm? Well i've used a HKS super drager on my previous r33 gts-t and i liked it, never had problems with the cops at all..its pretty silent at low revs but opens up real hard on high revs...I feel the exhausts all give about the same power gain, but its the exhaust notes that differ between japanese catbacks and xforce, and perhaps durability is of another issue..the japanese exhausts seem to keep that same sweet note fer a long time, but other dodgy exhausts kindda give out a different note after a while compared to when its new...but well just my personal opinion..i would stick with japanese exhausts~ :)
Now im running a fully customised 3.5" exhaust system from japan on my gtr, mines stainless dumps, titanium split front pipes, 3.5" metalcat ( the flow on the metal cat surprises me, i practically feel not much difference comparing it to when i was running straight-thru), 3.5" stainless custom welded catback, it flows awesome but its quite loud cuz im running internals as well, but i did test using a silencer on it, brought the dB down by 3dB, but pretty restrictive....Here's how it sounds~
http://www.grouper.com/GlobalMedia/MediaDe...st=-1&s=7&q=gtr
RB25 is 4800rpm
RB26 is 5200rpm
cheers
Can anyone shed light to the current regulations in NSW in relation to what the RPM RB25's are tested?
Awesome ey! :)
I love my super drager!
  • 1 month later...
  • 2 months later...
Thought i'd bump this one - Emsta - noticed you've ended up getting a PEII.. how's it sound.. what else did everyone else end up doing..
My trip to america has prevented me getting a new exhaust :D
Sorry about resurrecting an old thread, was just doing some reading while having a cup of dilmah tea (supposedly the finest ceylon tea)
Couldnt be happier Links - I still have to slap the car on the dyno, will do that next service. But yeah, batmbls products and the trust cat, is fantastic. Its very quiet too, like, as I mentioned above, I liked the growl of the x-force, but the PE2, is very quiet, goes well when Im building up my car in terms of performance. Basically, got RE Customs to install it, and it was a straight bolt on job - the only trouble was a couple of the bolts that were hard to remove it seems.
In time, will get more mods done. Right now, I need a job :D
Edited by emsta2003
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
