  • Replies 83
i know i saw it somewhere. i will sus it out and let you know. the only skyline i've heard that wouldn't be over the db rating would be my mates. it has a 3" jasma with the double muffler. it has a center resonater and the rear muffler is an oval muffler. it goes into the muffler as 1 pipe, then in the muffler it splits into 2 pipes then comes back out as one. basically like an overtaking line on a road but with a wall down the center.
mines pretty quiet...
Neighbours dont have to much of an issue with it :D
JustJap/Steve,
Can I get an idea of how many dB the full turbo back xforce exhaust is? Have you guys done any tests on ones you've installed??
Anyone actually - wondering whether it'd still be "legal" - 90dB (i believe) in NSW..
might go get one done on the weekend. father in law works at an exhaust shop. will do a test with silencer in and out. i have split dump, 3" front pipe and cat, 3.5" x-force cat back and muffler is 3" x-force cannon. still has center muffler. i know it is supposed to be legal but i really doubt it. my father in law's falcon has a standard 2.5" sports system with both mufflers and it is quieter than mine and his is on the limit. but the only way to properly test is to do it the ADR way. it is as follows-
cones are placed at a predetermined distance, with a vehicle being accelerated through them at full throttle in a certain gear (usually 3rd). the peak db reading from the meter (a predetermined distance away) is recorded. runs in both directions are done, and a radar gun is used to ensure entry speed is around 55kmh.
a stock xr6 turbo is 87db, and a stock xr6t with just the center muffler removed, but stock piping size only just comes under at 89db.
Cheers guys..
If anyone has the details on it that would be great.. anyone had an sound tests done..
if I get it replaced i'll keep my stock one in case of getting defected
ive heard justin911's car, and i doubt its legal...
mine on the other hand would be :D
  • 3 weeks later...
Ok guys, I have come to a conclusion about the exhaust (after doing some really exhausting research! >_< ).
I have decided to stick with BATMBL r33 split dump/front pipe (s/steel) and the CATCO 3 inch large Cat - about $620. And for the Cat back I have decided to go with the APEX-I Bomber from BT-Revolution - about 750. (havent put the orders in yet though).
Total comes to about $1370 before fitting.
What do y'all think about this? Good combination?
i paid $400 for 3.5" cat back at mates rates. but that was still above cost by a bit. and that the price for the 3". ordered a 3" and got 3.5" at same price.
i have seen the x-force cat back systems on ebay for i think it was $599 for 3" and $699 for 3.5"........or it was $499 and $599....either way there was $100 difference.
im gettin my exhaust from exhaust technology in SA and they are freighting it up to me. (in western syd)
3" straight thru from turbo back with highflow cat (removable) with straight thru pipe to Apexi manual ECV to dual 3" tip.
turbo> 3" dump/front -> removable cat/race pipe->3" pipe ->Apexi ECV-> Dual 3" tip :D
think its $1400 to my door.. ill heatwrap it then install it myself in about 30 mins :D
stainless steal :ermm:
Edited by illusiVe
when x-force advertises that theyr exhausts are: "below 90db" or whatever the legal limit is... that is measured with the silencer on I'm pretty sure. It's over the limi without the silencer.
Still good value for money exhaust though! Thats what I'm getting.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
