it does make a difference.. regardless if the stock rubber hose isnt sucking closed completely.. it still flexes each time you boost it with the sucking pressure of the turbo.. recently made solid intake pipe for a mates r32 gtst.. noticebly difference in driveability
just recently made mine due to putting a bigger turbo on, i have a catch can but u still need to vent the air from your plumb back blow off valve into there if your still using the standard blow off valve that is!
doesnt matter wat you make it out of it'll work the same.. alloy for lightness stainless for shinyness(stays shiner longer than alloy) or mild steel on the cheap
all you need is a mig welder n some mild steal bends and a drop saw
its rather easy to do.. if you want alloy.. probaly better to buy the apexi kit..
if you want stainless for showy shine.. and you have your own tig.. and can weld .. go for it
