after rebuilding and replacing the turbo a valve has let go on the 'test run'
this was only at 10psi and under 5500rpm so not heavy conditions. at first it was a misfire so i changed coil packs, spark plugs and ignitor amps. nothing. ran a compression test, and it came up with 0 compression in cylinder 4. so it something to do with the valves
i pulled the rocker covers off and rotated the cams and all 4 lifters work fine so its not the valve springs. all looks fine from the top of the engine. so it must be a bent valve or something from the bottom... but does anyone else have any ideas? is there something ive missed in the diagnostic?
can anyone give me any advice with regard to pulling the head off to check from the bottom if a valve is stuffed. how much for a workshop to do this kind of job or any help is greatly appreciated. my budget is already stretched from the turbo job so i have little cash to play with
thanks in advance for any help, it is much appreciated
https://www.sau.com.au/forums/topic/11872-busted-valve-help-needed/
Originally posted by adam 32
thanks, i will definately need valves, hopefully not pistons - how much you want per valve?
how could the 2 have been related? im writing it down as bad luck as i was only running the new turbo at 10psi... any thoughts, ideas?
maybe a bolt or sumthing hard acidently fell into inlet side and bent valves
let us now what actually happened ie bent or burnt valves or holes in slugs
never seen a rb20 burn a valve yet
vavles...... $10 ea
Removing the head, dont use alcohol.
Big job, if you choose to accept it yourself
elaboration, ever notice how on a rb twin cam how something could fall into teh exhaust manifold and land right on number 4, its teh most direct route..
A mate once found a micromachine in teh sump of a 253, might find that lock nut after all
yep several times
I dont know how fast you work but put a weekend aside
veale should be able to get your head gasket over.
if you do it yourself theres two 10mm headed bolts holding head to block on the rear two corners on the outside of the head.... dont forget em dont screw up for timing belt settup......
workshops ...... contraversial and political
theres two in bentley area id trust
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
