im guna get flamed for this.... bring it on i guess.....
what are the chances of a 500hp r33 gtst, using stock box and diff, to run slicks and not break anything? im not talking a soft launch, im talking , front wheels reaching for the sky 8500rpm clutch ripping type of launch...
i have a set of michellin slicks and mt front runners, and i really want to improve my launches, and ive notice alot of hipo skylines do a rev limitting launch... i know it isnt healthy to do this, but will this much force shear a standard drivetrain? any people had experience with this? any and any reccomended slicks??? PLEASE HELP!!!
Edited by danielson
https://www.sau.com.au/forums/topic/118724-time-for-slicks/
go to www.wild1motorsport.com
and view my skyline
my advice is get a gtr diff cradle
and good suspension
such as HKS
rev to 8000 and drop the clutch
the clips on the site are with MT street tyres
i have the slick pass which i ran 10.8 on my computer which is ready for uploadinng and will be uploaded this week
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2185600
500hp, slicks, preped drag strip? Rev Limit launch, standard driveline = something broken.
That is my "expert opinion".
So true………
MT ET Street radials + 320 bhp + good suspension + 6,000 rpm launch = broken clutch
WSID 10/5/06
;) cheers :D
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2192966
What car is this?
Our white R33GTST project car, sort of a replacement for the R34GTT daily driver I had a couple of years ago. Bought it cheap a few months ago, needed rego and SOME work, it's getting there. So far it has a Power FC with Boost Control Kit, standard R32GTR intercooler, alloy 120 degree pipework, Bilstein and Whiteline suspension, GTRGeoff HICAS eliminator, Magic cat, Nismo FPR, GTR fuel pump and a quick and dirty road tune by me using the Tech Edge A/F ratio meter.
Following the clutch failure at WSID, right now it is getting a new clutch, lightened flywheel and serviced gearbox (no synchro on 4th and 5th). Plus I had to drive it home clutchless (testing my dog box rpm matching skills). We just wanted to get a base time on the standard turbo, but too much traction from the MT ET’s for the unknown clutch.
A GCG ball bearing high flow is ready to go on shortly with a Performance Metalcraft split dump, followed by a set of injectors and a pair of 256 Tomei Poncams. Looking for around 265 rwkw and a mid 11's 1/4 at around 125 mph. Before then it will get some new DBA slotted rotors, a set of Hawke pads and a timing belt change.
Plenty to do, no time to do it in.
;) cheers :D
Edited by Sydneykid
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2194007
cool, thats fairly similar spec to my car actually
you think a Auto gearbox with valvebody, shift kit, and transcooler would be fine if I used Mickey Thompson Street ET? considering stock torque converter is arround 2000rpm only and not 6000rpm dump the clutch launch ehehhe
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2195018
Hi, as you increase the engine torque output you will find the torque converted stalls at a higher rpm. For example I can get the Stagea up to 2,500 rpm on the standard turbo which gives 11psi at launch. This generates considerable heat, so make sure that you have a decent transmission cooler.
If you can spin the wheels now, then decent tyres will help. I like the MT Street radials as I don’t have to change front tyres and the guys are down to low 10’s using them, so they obviously work OK.
:P Cheers :)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2200489
:D Cheers :(
Hey SK thanks for the advice, I have a oil temp gauge hooked up to my transmission cooler to monitor temps.
But my engine is a RB30 with HKS2535 so it boost pretty early
Plan to stall it on the line and launch as hard as I can with MT Street ET
My street tyres are Bridgestones RE01 and its very easy to spin them on first gear
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2201016
5500rpm launch on MT ET Street Radials. Clean sheared the CV Shaft in half. 6500rpm and the bearing cage explodes. Big.
I only make 355hp @ the tyres (approx 410 engine hp).
Adrian
f**k me man, u would have thought the clutch or box would go 1st, not the driveshafts.... good job!!!
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2201654
  • 1 month later...
whats with this jimm berry clutch your talking about, who deals with them? are they really as good as you seem to think?
I think Jim Berry is in Brisbane, Aaron at Wayne Park Automotive organised a clutch through him for me and he knows Jim quite well... Clutch is a single plate with about 2800 pounds clamp pressure std is about 1800. I hear people talking about 4000 pounds, but so far so good with 2800. have launched the car countless times and never a problem, just dial up about 6500 and let it out quiclky and all four light up on the std gtr 16's. 18's now fitted but yet to launch it with the increased traction.. nice smooth easy clutch to operate...
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2294684
Jim Berry is the name of the owner/guy who makes custom clutches for all types of applications. He swears by a big single even for 800hp+ drag cars (subzero soarer, millenium motorsport supra)
he hates twin plates with a passion, so dont even ask him what he thinks of them >_<
also he is quite 'cheap', bout half of what youd pay for a jap twin plate :D
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2296470
Adrian
Hi Adrain, I keep telling you it's not the max power thats' the problem. :D:no:
It's the NOS making the axles brittle. :P:D
:D cheers :D
SK
Don't forget the Bass Junky Air Deflector ;)
I wouldn't know, I don't have one :D
:D cheers :D
Edited by Sydneykid
https://www.sau.com.au/forums/topic/118724-time-for-slicks/#findComment-2297790
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
