correct alex hence it should be good buying for anyone interested in upgrading their turbo.
i bought it to use on this car but GCG suggested their R33 hiflow turbo would not be the best choice on a neo RB25 so it is sitting there looking for a good home (it has been sent back to GCG to be checked before sale).
btw i have an R33 GCG hi-flow with less than 5000k on it if someone is looking to upgrade their turbo.
how much are you looking for it? i was going to upgrade mine in the next few weeks during my manual conversion
LOL, why did they say it isnt a good choice??
R33/R34 turbos are interchangeable and the highflow of both turbos is identical (AFAIK), apart from the R34 turbo having a slighly larger (debatable) rear housing.
Its not the turbo that will be your limit anyway (maybe 230awkw vs 240awkw R33 vs R34), its the way you tune the car. I think it wont be easy to max out the turbo with piggy backs....
alex the rear housing is different on an R33 vs R34, it is not questionable. the outright power goal was not the issue it was whether the smaller turbine housing could be an issue on a neo RB25. in life you sometimes have to take the advice of professionals that work in that field. i am not a turbo expert but i have seen enough threads by disappointed punters that mismatched turbine housings to their application and have spent $$$$'s chasing their tails trying to fix it.
who said anything about piggybacks??
terminal pm sent.
sure is alex
the powerFC (all things going well) will be fitted in the next few weeks and then we can see what the drivability is like down low. the midrange and top end won't be an issue.
the R33 hi-flow would make plenty of power for my application so an extra 15kw or thereabouts is neither here nor there to me but for the reasons above i will use a hiflowed R34 turbo to avoid any potential issues. i am trying to re-coup my costs on the R33 turbo.
Edited by wolverine
the guys at plazmaman installed it and they used this as a test mule for a kit they will offer.
the price i paid may not relate to the retail cost for the kit since i was the first one.
i have a plazmaman FMIC on my R33 and i found the service and "care factor" very high with plazmaman after i ran into some difficulties installing the kit (not due to any fault of the kit). the patience of oyay & alex and their desire to ensure i was completely happy should be used as a model by every other workshop.
in addition, i asked them to look at making a replacement pipe from the afm to the turbo although if looks to be a complex pipe that might have too high a cost to go into any production unless there is enough demand from skyline/stagea owners.
i imagine the kit is available if anyone is looking for an alternative to the other kits on the market.
    • Por qué no los dos? Body colour red with black stripes down centre, onto bonnet and bootlid.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
