Hi All,
just a quick question.. I am planning to purchase a pfc and then get it tuned after i get a FMIC.
would it be ok to get the pfc, plug it in and leave it "untuned" until i get my FMIC (prolly about 2 months down track)?
Mods I have:
turbo back 3' exhaust
hks air pod,
mbc set to 10psi
I guess the question i am asking is will it be safe to the engine to not tune it and leave it standard until i get the cooler?... will i still notice any power differences in leaving it "untuned" in the meantime? (i.e. after i plug it in)
Cheers :wave:
-JD
https://www.sau.com.au/forums/topic/118777-power-fc/
taken from:
http://members.dodo.com.au/paul/docs/power...powerfc-faq.htm
Can I drive around without it being tuned for a few days? Months?
You can drive the car around as you would normally but you should take care not to put stress on the engine. Basically don't fang around in it, as you could be running unsafe A/Fs etc and just causing more damaged. Best to get it tuned. Make sure you watch the knock levels if you do this to make sure there isn't excess detonation.
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2186413
taken from:
ahh cheers paul!
that pretty much sums up my question! :wave:
Has anyone else done this? and found it to be ok?
Cheers,
-JD
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2186437
I hammered my car around for about 2 months before I got it tuned. Standard powerfc maps run as rich as hell so you're not going to hurt anything.
Just keep the boost below 10psi and you'll be right.
8psi standard maps - 140rwkw
13psi standard maps - 165rwkw
13psi modified maps - 209rwkw
:D
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2187269
the tune is in nvram so flat battery wont erase. there are two ways to loose the tune;
1) ETC, DATA INIT, YES, Reboot car
2) incorrectly wire in ECCS relay so it's unable to save changes when power to car is turned off. this is usually happens from an engine swap install
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2188649
just keep an eye on the knock meter... i've been driving mine around for 2 weeks on the base map. the powerfc base map appears to run stupidly rich, just going by the rate that it's guzzling fuel even with conservative driving!
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2189080
As posted elsewhere, the R33GTS has Magic cat, Kakimoto 3" cat back, R32GTR intrcooler, 10 psi boost and a Pod filter.
The default maps in the Power FC most definitely DO NOT run stupidly rich, they are around 11 to 1 after boost build. However the ignition timing is very advanced (compared to standard). We were getting knock over 70 occasionally on Optimax (98 ron) and Ultimate (98 ron) with no difference between them, as you would expect. Filled it up with Optimax Extreme (100 ron) and knock is now zero for 99.9% of the time and we only ever seen 20 once in a month of driving everyday.
So my suggestions are to watch the knock readout and the dash flash warning. If you are getting some flashing, try Optimax Extreme (100 ron) that should fix the knock problem.
:D Cheers :D
Edited by Sydneykid
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2189280
thnx paul but last night i was driving it and it looked like it had no power to the hand controller coz the screen sort of faded heaps then restarted a few times , after driving about 30 mins in a highway the screen stopped fading off...???
bad connection somewhere? Alternator dying??
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2192913
I had fuel mixtures less than 10:1 aftter 4200rpm
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2199076
What sorta mods?
We haven't experienced that until we change the turbo, with the standard turbo they (about 25 so far) are always around 11's.
Correction, I did encounter one with higher than standard fuel pressure that was 10.5 ish.
:P cheers :)
https://www.sau.com.au/forums/topic/118777-power-fc/#findComment-2200543
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
