Hi peoples,
ive been toying with the idea with a garret gt2876 with .7 front cover rated at 440 hp on a rb20 eng. I would make an adaptor plate to fit the standard rb20 manifold.The rb 20 is in a 180sx. Most rb20s ive seen with t3 flange turbos are very laggy.
Has anyone done this and how did the car drive?
Thanks Michael..
https://www.sau.com.au/forums/topic/118785-t25-flange-440-hp-turbo-on-rb20/
OK.
Any other ideas with t25 flange? im looking for between 220 and 240 rwkw with plenty of power around that 3000-3500 rpm. Previously i had a r33 that made 287 rwkw with a GCG internal waste gate turbo but couldnt run less than 17psi due to the flapper valve not being big enough. That eng made plenty of power down low and now going to rb20 is a bit laggy considering its only got a r33 turbo on it.
Michael...
Thats the RB20 for ya mate.
Have a read of the RB20 sticky thread
The the sticky "Forced Induction Guide" there is lots of RB20 info threads... but get used to haveing no torque. Its part and parcel of owning an RB20 powered car
sorry to say mate.. but its a rb20 if you want heaps of power around that rev range.. you might even have to go a 320hp GT25 by garrett.. but than your probaly looking at around 220ishrwkw (rough guess)
rb20's are wierd with turbo choices.. glad i never ended up modifyn my rb20 as the cost i could have spent on it ive ended up with a 26 with a few little mods instead but each to there own
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
