Hey peepz,
Im chasing a couple of parts for my Series1 R33
I need a : Bonnet
Both Headlights
Radiator
Thermo Fan from the front of the AC unit
and a grille
If anyone has any of these please let me know, I need to get my car back on the road asap.
Cheers,
-Dave.
https://www.sau.com.au/forums/topic/118794-need-a-couple-of-parts/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
