Hey all, my A/C doesnt seem to work, I know a little about how these things work in the skylines, but was wondering what this sensor is for, and where the hell the wires *should* be going....
If somone could help me out here, it would be great ;)
(see attached picture for what I'm on about :) )
Cheers,
Steve
https://www.sau.com.au/forums/topic/1188-can-someone-tell-me-what-this-is/
Cheers guys :D
So would I be correct in saying that with it not connected like it is at present, the A/C won't go cold? It seems as tho no matter what temp you set it on, its always on warm. The A/C compressor clicks on in the engine bay, so that sounds o.k...... I don't know. Does anyone know any more about this system??
Cheers,
Steve
From memory, it is a tube that sucks air into the sensor which is elsewhere... I dont have the R32 anymore so I cant tell you exactly :D
The trick is to hold the down arrow for 5 seconds after it gets to 18 degrees and FC comes up, it stands for F...ing Cold, vice versa when it gets to max temp, hold it up and FH comes up :)
Kewl Bozz, cheers :D
I tried that, and it certainly does force it to hot or cold, but after I checked the self diagnostics on the climate control, it tells me the sun load sensor, and the internal air temp sensor are no good.....(well obviously :) ) What sorta affect will a malfunctioning sunload sensor have on the system? See, even in FC mode, the A/C won't go cold either. (I also noticed the fan infront of the A/C condensor doesn't operate)
Oh yeah, and where are the two plain black wires from the internal temp sensor meant to be going, mine are cut, and I can't for the life of me see where they are meant to go??
Thanks heaps for the help so far guys, This site ROCKS:burnout:
Steve
Guest Crazyfcuk
take it to a aircon specialist, sounds like u need ur aircon re gassed, i had the same problem last week. #22 & #25 (internal and sun sensors) came up reading as failed, they have fixed it all up now tho and it runs like a dream. take it to them and see what they say.:burnout:
Guest gee-wizz
I think i had a similar problem. The a/c was working fine (had it serviced) but the system was always blowing hot air no matter how cold u set the climate control. I took it to an auto sparky and it turned out a fan or rotor somewhere in the system had broken loose and had to be resoldered. been working perfectly ever since.:D
Cheers all for your help :D
Well, after doing a little more research, I found out that you have to be in direct sunlight, or use a bright torch directed straight into the sunlight sensor, otherwise it renders a fault. I did this, and sure enough only the disconnected internal temp sensor reads as a trouble fault now :P (and its pretty obvious why it does :) )
Thanks all, and if anyone can tell me where the two black wires coming outta this sensor actually go, it would be freekin excellent :)
Thanks again,
Steve
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
    • Well found out it’s a 60th anniversary gtst from that it came with 205-55r15
