Hi all, my friend just bought a R32 Skyline with the RB20DET engine 99xxxkms. Light modification of only air filter and a cat back exhaust. Now here is the problem, occasionally at idle and while driving the car will miss, sounding like a WRX.
We have changed the spark plugs and cleaned the plug boots but it still misses. Changed the fuel filter, still misses. Unplugged each injector at a time, no difference. Unplugged each coil pack at a time and found the last coil pack wasn't working so we got another coil pack and put it in thinking it would fix the problem. No good car still misses, to be sure we swapped coil packs around with ones we knew where fine to be sure it was a coil pack, still the same. Checked ignition timing, all good.
So we are running out of ideas as to what to check next. It only seems to miss when it gets hot not while it's cold but the funny thing is that when it's missing and you give it a bit it will drive fine and then sometimes it bog down. We checked the fuel pump the easy way by clamping of the return line and the revs picked up so the fuel pump is fine. We will do a fuel pressure test later but i need the specs. If anyone has them then please let me know.
We have even cleaned the airflow meter and still no good. So can anyone gives us any other things to check? How do we do a ECU fault code check? Any help would be greatly appreciated as it's driving us mad.
Edited by honey
https://www.sau.com.au/forums/topic/118810-rb20-sounding-like-a-wrx/
We thought that too but have swapped it with another igniter module from a friends car that works but problem is still the same. Any more tips??
Then it's the wiring loom onto the suspect coil; check for a minor break in the wire.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
