Just purchased a set of std R33 GTR brakes and would like to upgrade the rotors before fitting them on my Gts-t. I am looking for Std sized (324mm), 2 piece, slotted rotors.
Thanks
Alan
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
