Guest jimmyd17
Originally posted by Fast31
I would also suggest 4.11 diff ratio's. [/b]
Thanks Fast31, its great to hear from people that have actually done the conversion. Thanks for your input, i appreciate it.
I understand that the 4.11 ratio is out of the pintara's... how did you go about putting that into the skyline diff? I am presuming you still used the skyline diff, as it is stronger and has the 4 pinion centre rather than the pintara's 2 pinion...
Also, how would the 3.889 diff out of an auto skyline line up against the 4.11... and what about the 3.7 out of the manual skyline?
Thanks heaps!
Jimmy I would suggest if you are new to the engine conversion game, just grab yourself an r32 RB20det front cut and get someone to swap it all over for you as is.
I think you will be more than happy with the performance, I would estimate it to be 1 second quicker than an RB30 manual over the qtr on standard boost alone, put 14psi into it and you'll crack a 13......which is a big difference to the RB30!
I myself have Turbo'd the NA RB30 in my Skyline....
Guest jimmyd17
Thanks PSI_GTSII... these are the reasons i want to do the conversion myself: 1, i dont want to spend a lot of money on it. 2, i really want to learn. 3, i have time on my hands. 4, i have another car so it doesnt need to be finished in a hurry. 5, i have a garage pretty well set up....
Why do you say; get someone else to do it? and how much do u reckon it would cost? is it worth it?
Thanks again for your input
Don't got the Pintara Centre.
get an IMPORT diff out of an R31 coupe.
I'm pretty sure they are the R200.
they are 4.11, LSD
and tough as nails mate, they can handle 200+kw without a drama.
With the 4.11
you'll have a better off the line take-off, but the trade is your car will rev's will sit a little high on freeways n stuff.
But it's not like a 1000 RPM difference or anything so it's all worth it.
Don't bother using the Pintara Diff bits/borg waner parts, they are not designed for any power and you'll just have drama's.
like i said...
www.r31skylineclub.com
There's heaps of info on the forums there.
it's all been done before mate and there are a number who have done it.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
