joexiong Posted May 21, 2006 Share Posted May 21, 2006 Hi, Can anyone please tell me the difference with diff ratios between a r32 gtst auto diff and the manual diff? I've just recently did a manual conversion with a rb25det gearbox on my r32. I also have a manual diff laying around so i was wondering which one is better to stick to? Thanks Link to comment https://www.sau.com.au/forums/topic/118830-difference-between-an-auto-and-manual-diff/ Share on other sites More sharing options...
Guilt-Toy Posted May 27, 2006 Share Posted May 27, 2006 Hi,Can anyone please tell me the difference with diff ratios between a r32 gtst auto diff and the manual diff? I've just recently did a manual conversion with a rb25det gearbox on my r32. I also have a manual diff laying around so i was wondering which one is better to stick to? Thanks Usually the auto is a shorter ratio. Put the manual in for better fuel economy and longer gears - or if you like it zippy and short keep the auto dif in. Link to comment https://www.sau.com.au/forums/topic/118830-difference-between-an-auto-and-manual-diff/#findComment-2206490 Share on other sites More sharing options...
Pal Posted May 27, 2006 Share Posted May 27, 2006 i got a conversion and left the auto diff in, getting around 450 to 500 a tank. thats around 11l/100k's. from what i remember the auto diff is around a 4.33 and a manual is 4.11. Link to comment https://www.sau.com.au/forums/topic/118830-difference-between-an-auto-and-manual-diff/#findComment-2207050 Share on other sites More sharing options...
predator Posted May 27, 2006 Share Posted May 27, 2006 auto is 4.3. now I've converted mine to manual, it pulls quite nicely using the shorter ratios, so i'd recomend leaving it. Mine sits at 3000rpm at 110km/hr, which is ok by me. Link to comment https://www.sau.com.au/forums/topic/118830-difference-between-an-auto-and-manual-diff/#findComment-2207084 Share on other sites More sharing options...
dan cohen Posted June 20, 2006 Share Posted June 20, 2006 Does anyone know how much effect is there on the speedo readings when you change diff ratios? Link to comment https://www.sau.com.au/forums/topic/118830-difference-between-an-auto-and-manual-diff/#findComment-2272059 Share on other sites More sharing options...
