dammit I have the same problem!
Just happened tonight and got my exedy clutch fitted just over a month ago now.
Squeaks when depress clutch when driving to change gear - neatural and depress clutch - no noise.
Hopefully this thread can help me!
mad082 - thanks for the photo!
mine was doing that too. neutral and in gear. caouildnt really hear it when driving though, only when stopped really, somewhere quiet.
I got it greased up when i had the car on the hoist yesterday, the squeak is gone, BUT....now i have this click click sound when i push the clutch in.
it makes 2 clicks as the clutch is pressed.
any ideas what that is?
thanks for taking the time.
its clicking from under the car. can only hear it with window open in a quiet place, like inside my garage.
added: i called my mechanic after we greased the fork to stop the squeak, and told him about the click. he said not to worry about it, it will go away, it's just clicking against the groove that's been made thru all the squeaking. i'm not so sure about that though.
Edited by Munkyb0y
it could be the slave cylinder clicking in a grove it has made. you really need to be under the car and have someone push the clutch in. it could also be the slave cylinder bolts are a bit lose, or it could be the spring on the clutch fork (where it goes onto the throwout bearing) isn't in the right spot.
wouldnt you know it. the click went away. my mechanic was right.
took it there today to get it up on the hoist, and just before we did, listened for the click...tada !!! gone.
thanks for ur help mad082.
  • 3 months later...
in case anyone else has this prob.
when i did a search i found alot saying it was the slave cylinder, needs to be chganged.
my clutch developed a really loud, annoying squeak. i mean embarrassingly loud.
so whenever i released the clutch, it would squea-ea-ea-ea-eakkk like an old lady's trolley.
wasnt like the previous squeaky rattle noise, which turned out to be the fork rubbing on the plate.
anyways, it was the fork again, but this time it was where it pivots on the rod inside. it was pretty dry and dusty at that pivot point, so i greased it up, and the noise is gone.
yeah,
mad082 explained it on the previous page.
have a look at this pic.
http://www.skylinesaustralia.com/forums/in...st&id=39884
undo the slave cylinders (2 bolts) and remove it.
then pull the rubber boot off, and get a torch, you'll be able to see in where that fork runs.
you'll see another rod inside running at 90 degrees thru the fork.
at that point where they pivot is where i greased mine. i used thick grease.
you'll probably need a hoist, or at least some decent clearance to get right under there.
Just thought id remind you guys its extrememly bad to apply wet grease to anything inside the bellhousing as it can and will find its way onto your prssure plate/drive plate/flywheel eventually. Better to use a dry lubricant like graphite powder.
  • 1 month later...
I CONFIRIM;
The bit that was squeeking in my car was the actual metal pin that goes through the clutch bracket. I sprayed it with WD40 and it is all cool now.
You have to physically lay down on the floor of the car and so u can see the whole clutch bracket. The spray the clutch metal pin..its fairly large u cant miss it. Make sure u have a torch aswell and the red straw bit to direct the spray into the gap of the pin.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
