First off excellent place to talk and am happy to have found it!
Just got myself an R33 stock as a rock except for a jasma kakimoto exhaust but already have the bug and want to modify it, but I need help!!!
So far this is what I have…
Pod Filter: Apexi Power Intake
(can I just get the pod or do I have to buy the specific kit for my car? Whats the difference?)
Skylines GTS-t kit $190 or Z32 AFM filter for $130
FMIC: Hybrid GT-spec
Value vs performace is this the way to go? 780 x 300 x 80mm Core width : 600mm
$880 installed
From there I was going to purchase a new front bar to let the intercooler work better and move on to
Boost Controller: Apexi ??
Not too sure need help here guys!
Apexi Power FC: around 1000 tuned?
Is this the best road to take for my skyline, mostly for road maybe go to track every now n then?
Thanks again!
https://www.sau.com.au/forums/topic/118862-virgin-skyline/
As for the PowerFC.
Your looking at purchasing a powerFC for around $950+ (cheapest I've seen yet for one).
Then a tune which can take anywhere between 2 - 3hrs.
Cost for a tune is depending on where you go.
Myself and many others would probably highly recommend Matt Spry down the gold coast, however, be aware the cost is alot more then others charge but well worth it!
https://www.sau.com.au/forums/topic/118862-virgin-skyline/#findComment-2188329
May I suggest your best bet for first round mods are...
Suspension, brakes.
Suspension get the Sydney kid bilstein kits. Bang for buck its awesome, dont throw your money away on coilovers, they are not worth it.
Brakes just go get them checked. Braided lines, better pads and a good brake fluid is all you need, then just upgrade the rotors when they need doing.
Then some decent tyres so it all works.
Trust me you will get more enjoyment out of those mods than you will out of power mods. Especially with the way cops can be these days.
If you do need to do power mods tho. Best to do smart mods.
PFC good gains can save you petrol too.
Pod, its only going to get gains if it can get cold air to it, so a box around the pod, and a bit of pipe to it will help.
Split dump/front pipe, good gains.
Boost, a bleed valve would be fine, just get a good quality simple only, no dual stage etc. Electronic is better if you can afford it, but up to you bang for buck I dont think its worth it.
FMIC, if you are only running 10psi or something I PERSONALLY wouldnt spend the money, if you are going for 13-14psi I would. That is just me, you might want it for looks.
That should net you some good gains, anything above that will start to cost serious money.
https://www.sau.com.au/forums/topic/118862-virgin-skyline/#findComment-2188471
a bleed valve is a manual boost controller. a BOV is different and you don't need to upgrade your BOV until you start runing serious boost unless you want to make pretty noises.
Even a second hand Electronic Boost Controller would be good if you can spare the cash.
https://www.sau.com.au/forums/topic/118862-virgin-skyline/#findComment-2188722
I personally use a GReddy Electronic Boost controller. I have heard that the Apexi AVCR are not that accurate and they only support 1.5 BAR of boost.
For most people 1.5 BAR is more then enough but it is something to keep in mind if you plan on going nuts with the mods.
There is a few second hand EBC on the forums which is a cheaper way to get into it. I believe a GReddy Profec B Spec II is approx $490 to buy new.
Come out to a meet sometime if your able and see what people run and what they have to say about various controllers.
https://www.sau.com.au/forums/topic/118862-virgin-skyline/#findComment-2189165
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
