but what I'm asking is what does the HICAS mean - is it 4WS or active diff or both?
HICAS comes on all skylines this means it has 4 wheel steering(for info do a search on hicas there will be 244,000 threads) A-lsd stands for active limited slip differential this is extreamly rare you are lucky if you have this it is a gtr vspec feature, basically it means you have the same differential as a gtr vspec see my attached picture for details.........it is a feature that costs an extra 5k brand new and is the best!
for all those that dont know do a search on a-lsd and you will find out,,,
is the lsd like the vspec gtr that turns to shit one it overheats and becomes a single spinner.
v spec gtr r shocking once the 4wd goes off( happens frequently at track days) and it becomes a rwd single spinner
just wondering if the gts version of the diff does the same thing
pete
Originally posted by KDR33
My R33's door lock when i shift my gear to 2nd, is that a safety shit or some thing wrong with my car?
In my car, i hear the hostess saying please fasten your seat belf, we are taking off soon.
  • 1 year later...
akeenan: thanks for the pic, but i'm interested to see what the plate says
Mine is an active LSD, built Feb 94.
Plate says RC41. the 41 is the rear drive ratio of 4:1 I think.
However, the difference in plate ID is in the sixth digit of the MODEL number.
Active LSD is the only model that has V as the sixth digit.
Bit belated response, but am only recent owner
cheers :(
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
