Just looking at upgrading my turbo soon (rb20det), r32 gts-t Type Mcurrently have the following mods
3 inch turbo back exhaust
Unknown cat converter
pod filter/sectioned off
running 12 psi
FMIC
Performance suspension
Looking to make the thing a bit faster. Dont car about how many KW ill be pulling (expect 190-200)
Looking at the 25 series 2 turbo with the nylon wheel. Dunno if ill be able to afford a highflowed one unless i get 2nd hand or something, heard quite a few different prices but was hoping for somewhere around 800 or 900 installed.
Anyway just looking through the dyno thread sticky and most people just post KW's not 1/4 mile times, although one guy posted a time of 14.65.. which is like .15 better than a stock 32 gts-t. Weirded me out. Any one give me a rough idea of what i should expect to pull on the 1/4 (e.g. how much better than the stock 14.8) on some good quality performance tyres with performance suspension with my mods and the 33 turbo? Perhaps the time rough amount faster the highflowed is gonna be, would help to if u know that.
If its not significantly better then ill just leave it without the bigger turbo, and try to make do with what i have :D
Did try do a search but the criteria is to open and at the same time to specific to get some decent results. if anyone finds otherwise, feel free to post that link here for me :D
Some 0-100's would be handy to (stock gts-t's hitting that in about 6.9 i think)
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/118921-wat-sorta-quarter/
You can get 160-170 on most RB20's running about 12-14psi depending on a few things...With a RB25 turbo your probably looking at about 180 mayb a few more at the rears...
As mad082 said, it comes down to driving, and how the car is setup. If you have crap tyres and crap suspension you cant expect to get a very good time because u will have trouble trying to put any of this power to the ground anyway regardless of what power your making. i would say high 13's is quite realistic with supporting mods. But that sed...all depends on the conditions on the day aswell.
Yeh tru all that, i think its reasonably well set up with full springs shocks under konig brand name (very damn hard suspension) and some 17X7 dunlop SPMAXX's which are top of the line (not to mention i weigh 55 kilos :)). Totally messed up somewhere in my readings somewhere though. Forgot to mention that i will Probably be running 14 psi on the new turbo with a remapped ecu but yeh. High 13's would be just wat i want, especially if i can get it with the series 2 turbo without having to have a highflowed one. The car could be quite detrimental to the ego's of stock $60000 performance cars everywhere with acceleration like that, sounds just about right :rolleyes:
running the extra 2 psi = no power gain and shorter turbine life? I have read of quite a few people running 14 psi so i assumed it would be relatively safe.. Cant see how it wouldnt equal a power gain though.. Up to a point more psi = more power.. you could probably get more power all the way until 20 or something id say (read something somewhere about flow and such which seemed to imply that too much compression would equal slow flow or impeded flow rates, something like that)
correct me if im wrong
you wont be running 14psi for long, maybe 6 months to a year. Wont you be just adding a hole lot of heat for no power gain
Its on an RB20... just incase you've missed that posted a dozen times.
RB20 you can run a little more than the R33
whoa whicked if i can hit something like that ill be very happy, time to start looking around for a turbo to lob on. Guess the for sale section is a good place hehe.
My old R32 with remapped ECU (thanks to Matt Spry) and standard turbo pushing 12psi managed a 14.3 on my first run with G-Tech. Tuned for 15psi I managed a number of runs between 13.7 and 13.9 (again with G-Tech).
Yeh tru all that, i think its reasonably well set up with full springs shocks under konig brand name (very damn hard suspension) and some 17X7 dunlop SPMAXX's which are top of the line \
Hard suspension will make your time worse, and 17x7 are the size of your rims, not tyres.
I am taking this from another thread which may have a generous dyno, but still none the less it prooves 160-170rwkw is easy (ive seen that on stock rb20 turbs) and 180+rwkw is a good goal for an rb20 with 33 turbo, obviously the 34 turbo will make a tiny bit more than a 33 turbo as im sure you aware.
You should be able to do a mid 13 with an rb25 turbs if you are a good driver :)
running 12 psi
FMIC
If its not significantly better then ill just leave it without the bigger turbo, and try to make do with what i have :P
Did try do a search but the criteria is to open and at the same time to specific to get some decent results. if anyone finds otherwise, feel free to post that link here for me :ermm:
You can run a little more boost on the RB20 with the RB25 turbo as the engine is smaller in size with supporting mods and 14psi 200rwkw is probably possible but im not sure how long the turbo would last at that boost level.
I managed a 13.6@105 with a crap 2.4 second 60 footer on a 30 degree day, with my R33 first time at drags. So in your case with similar power less weight better tyres and suspention high 12's may not be out of the question.
Ohh really? I suppose it IS set up for handling, uhm so tighter suspension = more bouncing, is that it? Wouldnt tighter suspension stop the sag more and help distribute weight around more evenly on take off. Not sure on suspension stuff
And yeh i know 17X7 is the size of my rims, the car was nowhere near me. There 225/45R17 Dunlop SPMAXX's which is basically dunlops top performance tyre so i think there cool for a bit.
Curious though, you 2 guys who ran mid 13's were your 33 turbo's high flowed? series 2 or 1?
Thanks (had to spend $1000 getting a new computer to get onto SAU, just when the turbo was within my grasp demit)
And yeh i know 17X7 is the size of my rims, ill post tyre size a lil later on, the car was nowhere near me. Its still not near me but they are very well fitted (did em myself :P) and definitely not to small for the rim, the sidewalls buldge slightly as a rim protector (with to thin a tyre they won't sit out) so there definitely wide enough to be putting the power down alright (can drop the clutch at about 4k RPM and get pretty good pickup).
do a search for posts by sydney in regards to drag suspention.
cheers
Well i made 162rwkw @ 14psi on a stock RB20 turbo.
Full exhaust, re-map, fuel pump and thats about it.
Dunno how but hey i was happy for so little mods.
But there are always those freak motors around etc so i'd be expecting maybe 170ish from a R33 turbo but you never know i suppose so whack it on the dyno and find out!
Edited by MADGT4
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys ๐Ÿ™. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure ๐Ÿ˜‰ Explenation is right there, i just missed it ๐Ÿคฆโ€โ™‚๏ธ. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned ๐Ÿค”. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
ร—
ร—
