Ive got 2, no boss kits, Brand New never used MOMO race
http://calibra.at.infoseek.co.jp/calibra/momorace.jpg
I just got that off the net but they are the same, but mine is new.
$320 ONO
Also got a 3 spoke dished wheel for $220ONO but not a MOMO
https://www.sau.com.au/forums/topic/118935-steering-wheel/#findComment-2202040
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
