Hey Guys... im going to attempt to install my FMIC in the upcomming weeks and just QRI05E (curious) :) to know where is the safest part to place my jack stands while working on the car?
Could some one please post up a pic showing where to place them under the car??
Cheers
https://www.sau.com.au/forums/topic/118956-jack-stand-points-needed/
um i placed mine just underneath my suspension arms (actual name fails me.. wishbones or something? i duno, independant bits at the front) on the rubber washers just as they join up with the rest of the under carriage. probably the best place to jack as the front as the sills will be a bit to far back for stability and are rather hard to access if youve got a kit.
Edited by r32 gts-turbo
i cant put them under the frame rails due to my trolly jack being too high to fit under the car after lowering it 3" : can anyone please post up a pic??
cheers
i know what u mean...
i have 2 ways of jacking up my car..
1/ piece of wood and bricks, which i drive the front wheels on and put the jack under
2/ get a scissor jack, jack it up from the side enough to get a mini trolley jack in, then get the big trolley jack in the front..
either way its a bitch
Try the frame rails under the floor but put a rag between the rail and stand.This will protect the paint.
Are you talking about the chassis rails? I was under the impressions it is an extremely bad idea to use these are jack points as they tend to bend and buckle.
I recall reading something somehere (either SDU or one of the UK forums) about a similar topic.. there's a nissan made part specifically for jack stands and skylines. I did add the item to my post skyline purchase shopping list (nissan part# LM450-60000), but don't know how much, or if they're available here.
  • Like 1
i use the points that ive circled below.. not sure what its called.. can someone tell me if its alrght to use them ??? im also curious where the correct place to put the jack is... i always get realy paranoid the car is gonna fall ;)
between the two circles is the front cross member/subframe, that is a good place to use. Be careful since the sump is a bad place to use. there is also the tow hooks at the front they are great jacking points.
also be very careful if you are putting the jack under the side of the front subframe, the lower control arm is not safe - it moves relative to the chasis when you jack the car up.
chasis rails are OK to put stands under *if* you use the thicker area towards the front and let the car down slowly. even better if you have to do this use a piece of wood on top of the chasis stand along the rail to spread the weight.
at the rear, like the pic says, use the diff or rear subframe.
the sils are a no no they wil crush for sure unless you are using the nissan scissor jack or a hoist with rubber pads (and sometimes even then)
tow hooks are great, strong weld to the chasis and easy to get to....I was pretty nervous at first, have a good look at how they are fixed to the car....I use them all the time now, so easy to get to :)
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
