Hi all,
am wondering atm to change the front bar i have on my car atm (BN on most 32's) and go for a full GTR kit for the GTs-T i.e. Gtr front bar, gtr skirts, gtr pods(not sure on these), gtr bonnet and grill, and a gtr rear spoiler. Anyone have any ideas on how much this will cost? And how hard to source this stuff? Also would like the small inserts as in the picture below/attached. Any opinions appreciated aswell on whether to keep going with the BN or go for the GTR kit.
Cheers.
https://www.sau.com.au/forums/topic/118960-gtr-kit-for-gts-t/
Whats a BN?
Off the top of my head some approx prices:
GTR copy front bar: $450
GTR side skirts - keep the gtst ones, theyre better, if you dont have them, budget another $500
GTR read pods - keep the gtst ones or as above fork out another $300
GTR rear spoiler $200 Maybe cheaper, noone wants rear spoilers anymore.
GTR bonnet - $700 plus latches
GTR grill $200
In my opinion if you have the stock side skirts and read pods, just remove the rear spoiler and get a gtr front bar, dont worry about the rest.
http://www.nismo.com.au
- R32 GTR STYLE FRONT BAR FOR R32 GTS-T
- INCLUDES SPEED HOLES FOR R32 GTS-T
- MADE FROM GEL COAT FIBREGLASS - READY FOR PRE-FIT THEN
- PRIMING AND PAINTING.
- N1 STYLE BAR SLOTS ALSO AVAILABLE
FRONT BAR PRICE: $550.00
BAR SLOTS PRICE: $150.00
http://www.justjap.com
- has a GTR frontbar
http://www.carmate.com
- has whole GTR kit
Edited by Rekin
Who cares if its a fake gtr, its got more than 1 reason for it.
1. Bonnet - i bought mine for $400 in perfect nick. it came with new latch mech. It weighs less than 10kg so a weight saving for the gtst.
2. grille - well about $150 second hand
3. front 1/4 panels - also made of aluminium so another weight saving there.
4. gtr indicators are required
5. rear wing - dime a dozen on the forum sale section.
6. u WILL need gtr side skirts as they are completely different.
7. rear pods are the same.
8. he never said he wants to badge it a gtr, so dont judge anyone.
The 32 gtr has the best factory body kit imo. Im currently putting together the stuff to put the front end on myself. I dont pretend my car is a gtr, nor do i bag anyone for what they want their car to look like.
At the end of the day its his car, and he can have it look the way he wants. Dont flame the guy, help him. Its what these forums are for, but most people forget....
  • 2 months later...
GTR bar wont fit. need to get fibreglass GTR bar to suit GTST, i just bought one from JS Auto Imports. Excellent quality and fit. Also does N1 vents and lip, grills etc. Give him a ring. 0405 153 290. his name is Josh.
Hi all,
Cheers.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
