People(s),
I wanted to buy a 600X300X75 fMIC (type Hybrid) for my R33 Series 1. I don't want to change the front bar or put on a kit so want to put it under my standard series 1 bumper. Will it fit, and if not what size will fit. I don't particularly want to start cutting out the front intrusion bar.
I also understand that the front intrusion bar will sit infront of the intercooler : : , i have seen that some have no intrusion bar in front coz it's cut or is it coz they sit it infront with a bigger front bar.
Please help before i buy something i will regret.
Thanks.
:P
Cant really answer your question, other than to say plenty of people have front mounts with stock series 1 bars...
but you might want to consider this, and save yourself some $ on the hybrid
http://www.skylinesaustralia.com/forums/in...howtopic=117938
I fitted one of the hybrid copy kits onto a series 1 r33 not long ago.
The cooler will fit but you have to cut away some of the bumper support, other wise you have to get an aftermarket front bar. The bumper itself has to have a fair amount cut from it aswell as the fog lights , they will have to be trimmed .
This all depends on where you mount the cooler but with the piping kits you are restricted on where you can mount it.
Hope this helps... cheers
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
