The other day i cleaned my AFM with contact cleaner and it has made my fuel consumption increase. before i cleaned it i was getting 420km outta a tank, now its down to 330km (same drivin style). I have a rb20det, stock ecu, not cat, fmic, r43 turbo and 7psi boost.
Can i lean out the mixture using the stock ecu?
What are some ways of decreasing fuel economy? (dont say lift up the right foot coz i drive like a granny mostly)
https://www.sau.com.au/forums/topic/118977-decresing-fuel-comsumption/
ecu remap or piggyback computer
remap or apexi safc
you need to bend the afm signal to make the ecu think more air is coming into the system than actually is, so it leans it out based around the "apparent" amount of air thats coming report (reported by the afm bender)
I was getting 500+kms to a tank before a chip, its now 550kms+ to a tank out of my rb20 cefiro on 12psi on an rb20 turbo.
I think you have another issue that needs to be addressed to sort out your fuel economy. I cant see how a piggy back or chip can solve the problem straight off. So you sort whatever it is out first, then go from there.
dont you dare use a resistor. get it tuned properly. youll certainly put the engine at great risk by using a stuid method such as an inline resistor.
either
1) get an safc and get it tuned
2) get a remapped ecu and get it tuned
3) get an aftermarket ecu and get it tuned
you should also make sure your onboard oxygen sensor is working and has been replaced recently (they last around 50,000k's)
you say that you don't have a cat running in between the exhaust system..
I recommend you put it back in.. firstly you won't get a fine and it should give you better fuel economy
How the f**k does a cat give you better fuel economy???
Dude just take it to a mechanic that knows what he's doing. Get him to check the base timing is correct and that the 02 sensor is trimming, check fuel flow and pressure(just for safety), have the injectors cleaned and then get a chip if it is still shite.
The problem with getting buildup on your MAF is that it desensitises the hot wire element therefore it reads that there is less air coming in and leans the engine out. Once you cleaned it it went back to being typically nissan programming rich.
SAFC wont help with fuel economy. If you lean it out on low loads and RPM, it doesnt take long for the ECU to learn around it and attempt to maintain your AFRs at 14.7.
Its easily demonstratable if you have a wideband as I was doing my own testing with an SAFC a while ago.
I would replace your O2 sensor and then do an ECU reset. What did you clean your AFM with? Please don't say WD40!
I cleaned the afm with contact cleaner.
should i replace the O2 sensor thats on the exhaust?
HAving no cat doesnt improve fuel economy it just there to pass emissions.
Can the stock ecu be 'tweaked' to improve the mapping?
What he said.
Try and reset you're ecu first. Factory programming will be rich but it's possible that a reset may help things. Apparently after a reset, as the ecu re-learns it makes larger adjustments at first, then only slight changes after that. Dissconnect you're battery, step on the brake pedal a few times then reconnect the battery or leave it off for longer. Should do the trick. It can't hurt and it's free.
Surely this would be the other way round? For better economy, you'd want the ECU thinking it's getting less air, so it squirts less fuel into the mix? More air would call for more fuel normally, right?
I would have guessed that if you clean the crap off the wire in the AFM, the wire is more exposed to the actual air coming in, which would cool the wire down and tell the ECU to squirt more fuel. (as the ECU measures the voltage of the wire based on the heat the wire retains from the voltage being applied to it)
If the wire is protected by gunk, it would stay warmer and not see so much air, and the ECU will give it less fuel to mix with?
Correct me where i'm wrong, but i've cleaned everything on my car, and I get BAD economy... I was really hoping a SAFC would help fix this.
Give it a general tune up first.
New plugs, new O2 sensor, check timing, clean injectors, fit a new air filter element into the airbox. (piss of pod filter if you have one).
Check that the water temp sensor is reading/working correctly as this is used for cold start enrichment.
And see how you go.
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
