The other day i cleaned my AFM with contact cleaner and it has made my fuel consumption increase. before i cleaned it i was getting 420km outta a tank, now its down to 330km (same drivin style). I have a rb20det, stock ecu, not cat, fmic, r43 turbo and 7psi boost.
Can i lean out the mixture using the stock ecu?
What are some ways of decreasing fuel economy? (dont say lift up the right foot coz i drive like a granny mostly)
https://www.sau.com.au/forums/topic/118977-decresing-fuel-comsumption/
ecu remap or piggyback computer
remap or apexi safc
you need to bend the afm signal to make the ecu think more air is coming into the system than actually is, so it leans it out based around the "apparent" amount of air thats coming report (reported by the afm bender)
I was getting 500+kms to a tank before a chip, its now 550kms+ to a tank out of my rb20 cefiro on 12psi on an rb20 turbo.
I think you have another issue that needs to be addressed to sort out your fuel economy. I cant see how a piggy back or chip can solve the problem straight off. So you sort whatever it is out first, then go from there.
dont you dare use a resistor. get it tuned properly. youll certainly put the engine at great risk by using a stuid method such as an inline resistor.
either
1) get an safc and get it tuned
2) get a remapped ecu and get it tuned
3) get an aftermarket ecu and get it tuned
you should also make sure your onboard oxygen sensor is working and has been replaced recently (they last around 50,000k's)
you say that you don't have a cat running in between the exhaust system..
I recommend you put it back in.. firstly you won't get a fine and it should give you better fuel economy
How the f**k does a cat give you better fuel economy???
Dude just take it to a mechanic that knows what he's doing. Get him to check the base timing is correct and that the 02 sensor is trimming, check fuel flow and pressure(just for safety), have the injectors cleaned and then get a chip if it is still shite.
The problem with getting buildup on your MAF is that it desensitises the hot wire element therefore it reads that there is less air coming in and leans the engine out. Once you cleaned it it went back to being typically nissan programming rich.
SAFC wont help with fuel economy. If you lean it out on low loads and RPM, it doesnt take long for the ECU to learn around it and attempt to maintain your AFRs at 14.7.
Its easily demonstratable if you have a wideband as I was doing my own testing with an SAFC a while ago.
I would replace your O2 sensor and then do an ECU reset. What did you clean your AFM with? Please don't say WD40!
I cleaned the afm with contact cleaner.
should i replace the O2 sensor thats on the exhaust?
HAving no cat doesnt improve fuel economy it just there to pass emissions.
Can the stock ecu be 'tweaked' to improve the mapping?
What he said.
Try and reset you're ecu first. Factory programming will be rich but it's possible that a reset may help things. Apparently after a reset, as the ecu re-learns it makes larger adjustments at first, then only slight changes after that. Dissconnect you're battery, step on the brake pedal a few times then reconnect the battery or leave it off for longer. Should do the trick. It can't hurt and it's free.
Surely this would be the other way round? For better economy, you'd want the ECU thinking it's getting less air, so it squirts less fuel into the mix? More air would call for more fuel normally, right?
I would have guessed that if you clean the crap off the wire in the AFM, the wire is more exposed to the actual air coming in, which would cool the wire down and tell the ECU to squirt more fuel. (as the ECU measures the voltage of the wire based on the heat the wire retains from the voltage being applied to it)
If the wire is protected by gunk, it would stay warmer and not see so much air, and the ECU will give it less fuel to mix with?
Correct me where i'm wrong, but i've cleaned everything on my car, and I get BAD economy... I was really hoping a SAFC would help fix this.
Give it a general tune up first.
New plugs, new O2 sensor, check timing, clean injectors, fit a new air filter element into the airbox. (piss of pod filter if you have one).
Check that the water temp sensor is reading/working correctly as this is used for cold start enrichment.
And see how you go.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
