Howdy,
Here'd be my suggestion.
4 volt preout head unit. - $500
Splits in the front $300
Sub - $250
4 x 100 amp $500
mdf sub box $100 to make.
cables, wires - $50
$1600 - but will be a good stereo!
These prices are based on good shizzit.
You can get cheaper stuff at Jaycar and is not terrible stuff. But don't forget, you get what you pay for.
I'm sure there is a search you could do to find out even more!!
There is also a Car audio section to help you with installing it!!
Now that... is quality forum.
I would say save a little more, 1K could easy be spent on a decent headunit alone. Its just my thoughts you should go and see what sounds good to you.
oh dw about HU i forgot ive got 1.5k saved up just for a HU (plannin to get the new
ALPINE DVA-9860)
i mean 1k just on speakers n stuff
Without trying to sound like a smartass, you would be better off not buying that unit and saving your money,
There is nothing wrong with Alpine, I am not bagging the product, just that for about a $1000 less you would still be getting a unit that uses exactly the same laser assembly, pre amp, amp, staging ouput and tuner parts. You just lose some of the wankier things a high end unit gets nowadays.
And with an extra grand in the hand, the system would be much better overall. This extra money could also include some of the "hidden" costs.
- decent cable kit for your amp
- decent sub box
- sound deadening
- better installation ( after all it wont matter how good the gear if the install sux)
my 2c
ALPINE DVA-9860)
Exactly what do you want/need that you have 1k to spend on? Speakers and stuff doesn't help much. Or better yet, You have money saved for the headunit, what else do you already have, or have money for that is excluded in your $1k budget?
  • 3 weeks later...
ughmmmm
i got my dvd player for $250
wasnt like some over priced pioneer one. but did exactly the same stuff.
just go wateva headunit u want, 6inchers in the doors, 6x9's or more 6inchrs in the parcel shelf. and either to 10's or 1 12 or 15 inch sub in the boot. not over the top, and decent sound.
:P
I put some $149 Jaycar kevlar 6.5" splits in my R32 and they sound fine. Not top notch but they do the job. I used a $300 JVC MP3 CD with USB input headunit (JB hifi price) does everything I need with iPod input/control if i want more music in the car. Needs a sub to fill out the bottom end though which I installed last weekend.
If I was going to put splits in my R34 though I would not use the Jaycars.
i was at "Freeway Audio" in dandenong the other day and they were working on a hummer that had 3 way splits.....bloody unreal and looked even better..the cost of the spits were like 1200
You can spend HEAPS of money on audio. Look at a nice set of Dynaudio, Focal, Hertz, Boston (etc) 2-way splits ($400) for the front, and just a set of average 6-6.5" coaxials for the back ($100), find a 12"sub and box for $200 and spend the rest on a 4-channel amp and wiring. Jaycar's 4x100WRMS amp has more than enough power and sells for around $300. Run the front splits off 2 channels, bridge the other 2 channels for the sub and run the coaxials off the head unit and it'll sound awesome.
Edited by govich
At the moment ive got cheap ass 12" Boss Audio subs in there. $50 each. They are running off a $120 1600 Boss Audio amp.
I wasnt really into stereo's so i thought i would go something cheap, wasnt looking for a big system.....i think i went the wrong option.
It is as loud as a mates setup which had 2 12' rockford's (not sure which ones) running off 2 sony monoblock amps.
All up i spent 220 on subs and he spent over a grand?
They have both latest the same amount of time. Ive had them in there for about 2.5 - 3 years now.
Sometimes the cheap way works lol :P
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
