Hi there,
I've been doing abit of research into getting cames for the R34. Now from what I've seen there are two types of Poncams avaliable for the R34: type A (252/252) and type B (260/260).
Going by a few user comments it would seem because idle isn't drastically affected it would be wiser to go with the typeB 260 degree cams?
What I would really like to know is: is there anything else needed to fit these cams? Such as valve springs or adjustable cam gears?
And would I need to get a tune or require aftermarket engine management such as PFC in order for these to work/run properly? Is it possible to have the camshafts installed with stock ECU management?
Thanks,
Andy
a lot of this has been covered before, and i suspect abo bob / bassjunky / sydneykid could give you some info on r34 gtt cam specifics but it is somewhat pointless on a stock turbo'd neo 25t.
you would be mad to fit larger cams with stock ecu and stock everything else
Bass Junky lost power when he installed Tomei Type B cams with his std turbo. But when he upgraded to a hi-flow turbo he gained alot more, as the turbo was able to provide more air.
As Paul has stated above, you'd be MAD (and pointless) to install cams on a stock engine setup. Invest the money in a ecu, i found that to be my biggest bang for buck, before the turbo upgrade.
Thanks guys. Hmm I was just pretty sure that I read somewhere that sometimes cams are under-estimated and somtimes can be used before a turbo upgrade to bring out hidden potential.
If this is the case then I might leave cams off later in the list and spend the money towards a tune suspension goodies. :)
Oh and I do plan on getting a PFC sooner or later. Would prefer to have my fmic, turbo-back exhaust, fuel pump, fuel reg and boost controller fitted first though.
Cam gears don't help on NEO engines either.
No point in doing cams without a bigger turbo as mentioned above.
But in closer answer to your question:
You don't need anything extra like valve springs or whatever, they drop straight in.
I can also tell you that with no retune done I got 25rwkw extra from the type b poncams, it's now running very rich in the midrange and the detonation threshold has moved up about 2500rpm. All at the same boost.
Just dug up an old post before about exhaust cam gears so it looks look a cam gear is no help on the NEO engine abo bob. I know of one that had good results with a ex cam gear on a 33 gtst but am wondering if anyone else has had good results.
munna on an R33 totally worthwhile but do it when you do the timing belt. 10-15kw gains.
Satanic.
I promise that if you don't tell us how to get better results with our cams gears, that I will ban you and eat your first born.
I'm hungry.
Munna. There IS a gain to be had, depends on the dyno and the car and all those other things.
Do a search for something like "Cam* Gears dyno" and you will find a fair few throads about them.
Basically you retard the exhaust wheel by about 4 degrees and readjust base timing. It brings your torque curve over a little and gives up to about 10rwkw gain at the top.
Everyones experiences have been slightly different.
I just KNOW that from my experience to date (Satanic, I'm waiting for further information) that they have no effect on Neo engines.
Satanic.
Don't make me kill you and eat you.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
