TEAM IMPUL 18'
Japanese Light weight racing wheels $1850 ono
Wheels will be sold with no tyres (currently have RE55s fitted)
As used by JGTC (SuperGT) cars. 2 air valves on each wheel.
18 x 9" +38 all round
Will suit 200sx, skyline gtst/gtt, rx7 FD.
Melbourne only. email [email protected]
https://www.sau.com.au/forums/topic/118992-impul-ns-gt-18-light-weight-wheels/
any other sets u want to get rid off seein as u have so many sets
also selling a set of 18" Work Meister S1's http://www.skylinesaustralia.com/forums/in...howtopic=118999
Hi
Do you happen to know if they would fit onto a 32gtr...im not quite sure about the offset as i currently have 17x9 wif a +22 offset. Intrested if it fits..
They will fit... but the +38 offset is higher, which means they would probably sit inside the guards... might look a bit gay with the pumped gtr guards..
according to the offset calculator http://marksink.com/tire_wheel_offset/offset.html
Your new wheel will have the following characteristics:
The clearance from stut housing to the inside of the wheel will be 16mm LESS
The outside edge of the wheel will RETRACT in towards the body by 16mm
would love 2 get them.. awsome rims...but have asked around and have been told that they will sit in to much on the guards and and would look "a bit gay" unless i run spacers which i dont want to do... good luck with the sale
Hi, Is there any damage like gutter rash I should know about and do they come with centre caps? also do you have any pics with em on a R33 gts-t
Edited by "EN4CER"
there is some minor gutter scrapes, but nothing bad. these are track wheels after all, if you want something perfect i'd suggest buying brand new wheels.
no pics on a r33, but if you look at the r34 pic it will sit about the same.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
