me and my bro always let our cars warm up for 1 min, if temp needle is right at cold, then drive of slowly, shifting no higher then 3000rpm.. until temp needle is at normal indication. Keeping a auto skyline off boost is quite tricky, because at cold start, its running retarded timing too, so even the slightlest hill means it wants to at least get to 0 vaccuum. :D
oh we both atm use pennzoil 15w 50w semi syn
Edited by J_R32
By the time I get 2km down the road, the engine better be warm if it knows what's good for it because it is going to get the fork reved out of it and the full 15PSI boost up the motorway onramp... every morning.
But that's ok, because "Diamonds are Forever"
Edited by PTR33
Yeah normally takes a min - open garage, start car, back car out, close garage, then driven under 3k RPM until its up to temp before it gets positive boost.
It's silly, a waste of petrol, and can even be worse for your car, if you let it sitting there idling for 5+min etc.
Depends on the car... my current pride and joy (v8 commodore - until I get enuf ca$h together for the R33) gets started, left until the revs settle in (usually about as long as it takes to kick on the CD, get my sunnies, light a smoke and roll down the window). Then gets taken easy until the needle moves towards the H and settles between 1/4 and 1/2.
I don't see the point in idling for a long while - seen what it does to diesel generators (glazed bores = bad ), imagine it wouldn't be any better for a petrol one.
The beater (read for the train station) gets kicked over, dropped into gear and gone str8 away - but for $300... who cares anyway :D, come to think of it.. not even sure if the engine in that even needs oil :)
my dad always cracks it at me if I do this... he reckons if I start the car before I open the garage, and trip over something in the garage and pass out.. then I will do so in an unventilated room with a car pumping out co2 emmisions.. or CO if you don't have a cat..
My oil pressure gauge in my 32gtst works occaisionly, and does all sorts of strange things, as many 32 gtst drivers will know, I turn it on let the revs drop to 1100rpm.. then drive.. I try to stay off boost, but there's a lot of hills around my place, so sometimes this is difficult. Use motul 4100turbolite
geez.. we're all a little precious :)
30 seconds at most, drive off.. boot it if so desired.
It's usually only about a minute before you have to stop again when you come to the first set of traffic lights or whatever anyhow when you're sitting there idling again.
geez.. we're all a little precious :starwars:
Expecially when one spends ~6k on a motor/head. ;)
I so wish sometimes I did what sky30 did.. s/h rb30e for a hundred or two, drop a s/h rb25 head on, big turbo and boost the crap out of it. :w00t:
I usually let the car sit for about 1 minute then drive off try keep it below 3000rpm till the Power FC hand controller says the waters about 60 deg then ill take it up to 4 grand till its at its normal operating temp (around 72 deg) then boost till my hearts content.
i don't bother letting it idle that much...get in start it pic a song on the ipod empty my pockets and back out the drive way... then jsut drive off and keep the revs low and off boost... u end up at stop signs and lights so quickly it makes no difference...
