  • Replies 44
Tomorrow night for those who care - I will be there, Im pretty sure that Jayce, Erica, Mark and Luke will be too mabye even Andrew and Leigh...
I tried a long time ago to strike up some interest with everyone (see S*E*X it aint trivial) but to no avail... So the new plan is - If you want to go then go - if you dont then dont (sit at home and drool like an idiot infront of that so called "TV show" the OC)... Anywho, its up to you!
P.s.... Only the coolest and most dedicated ACT SAU'ers kept going when everyone else bailed, heh heh heh ;)
Edited by Bullet32
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2389642
well my smart idea of taking the other means of transport netted me a nice cold that i am still trying to kick so i am out won't be able to make it till the 22nd so see you all then :D
SOFT! :)
Whats with the empty edited posts Beau??
Edited by Bullet32
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2392817
Idiot so the Jerra club in Jerra ... gets the street directory out I see I see so trivia night on tuesdays the place to be huh? hmmm might go for a drive tonight and see whats the go
JaiJai,
did you happen to make it out last night? cause at about 7:15pm, a grey R33 with an SAU sticker on the back window cruised through the carpark and left without saying hi. thought it might have been you? :D
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2431511
no the evils of work! I will go next tuesday ive got a white r33 with a torn and damaged front bar with a dodgy hybrid intercooler....qld plates
yeah thats what you get learning hot to drift
buuut I will make it out next tuesday Ive got nothing on so hopefully
I'll be able to meet a few of you!
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2432457
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
