G'day peoples, need to sell my Ford TX5 and the rims on it are illegal and wont pass rego.
In need of some 16" or 17" rims, no wider than 8" and needs decent tyres.
Stud pattern for the TX5's are 5x114.3.
Located south of Brisbane.
Will be interested in anything under $700.
Thanks all
Musky
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
