Hey,
im looking for either cat-back or turbo-back exhaust for an r32 gts-t.
not fussed whether it is mild steel or ss.
thanks stephen
i have an r32 2&half or 3quarter inch exhuast with japanese jasma tip $150
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
